ACI management recommendation
t.houmaiza
Hello team,
Can someone point out the recommended ACI implementation ? Connecting the APICs with VMMs , management tools etc.. via an out-of-band network or In-band via the N9Ks ? If something would happen to mgmt , ACI will stop seeing the VM based EPGs for example ?!
Thank you
dpita
Hello
Regarding the last point of loosing OOB mgmt, i already have a action item to test what will happen from another question. I will try to test this out soon and report my findings.
Thanks Daniel,
Is there a document that list the recommended way to manage the APICs ,connect it to other tools,orchestrators IB/OOB etc.. ?
