ACI Nexus
AsimHafeez1
Beginner
Beginner
Dear All,
I connected  ACI Cluster with Leaf but its showing an error "switch mode support false" and second thing can someone help me to explain how that how can I use interface Vlan routing in ACI, Because we are migrating from Cisco 6509 (Core) to ACI cluster and Nexus as core.
Thanks & Best Rgards
Nik Noltenius
just a quick answer to your first question: Depending on which switches you use the APIC has to run a certain minimum ACI software release to work with them. I'd recommend to upgrade to the latest version of whatever train you're using (1.3 / 2.0 / 2.1).
Nik
