07-29-2020 09:40 AM
Hi All,
Does any one knows how to change the administrative distance of OSPF routing protocol in ACI for the particular route (Example: 0.0.0.0/0).
There is a option available to change the AD value for the whole VRF but not sure how to change it for the particular route.
Naga
07-29-2020 10:56 AM
07-29-2020 01:31 PM
Hi @NAGA1 ,
Administrative Distance measures the reliability of the routing protocol.
Asking to change the AD of a particular route that is discovered by a routing protocol is like saying "I want to change the value of this $1 coin in my pocket, but keep the value of the whole currency the same"
So what you are asking is just not possible.
You need to tell us:
Now, I'll take a guess and assume that you have more than one route to 0.0.0.0/0, one of them being generated by OSPF, and another by BGP, stice route or something.
I'll look out for your reply before putting time into answering your problem.
[Tip: To add pictures to you post, do this:
