ACI Same Encap in Different Tenants
I have 2 different Tenants.
I created an EPG in each tenant and different associated a static port with the same vlan encap for each EPG.
I got an error that the encap is already in use in a different EPG although they are in different tenants.
How can i solve this problem and keep on using the same vlan tag?
RedNectar
This is the reason that they added the per-port VLAN feature back in about version 1.1 or 1.2.
To activate it, you'll need to create a L2 Interface Policy
FABRIC > ACCESS POLICIES > Policies > Interface Policies > Policies > L2 Interface >+ Create L2 Interface Policy.
Scope: Port Local Scope
Then add this policy to the Access Policy Group that you have associated with the ports in question.
You'll find all you need to know in a blog post I wrote some time ago https://rednectar.net/2016/12/11/cisco-aci-per-port-vlan-feature/
I hope this helps
Don't forget to mark answers as correct if it solves your problem. This helps others find the correct answer if they search for the same problem
RedNectar aka Chris Welsh.
RedNectar
I hope this helps
