12-10-2023 08:32 AM
Hi Looks like cisco ACI simulator cannot connect to endpoint device. Is this true? for example after we complete configuration of all policies on the simulator for PC1 connected to leaf1 to communicate with PC2 connected to leaf2, we cannot confirm it via making PC1 to ping PC2. Is there a replacement for this? Thanks
Solved! Go to Solution.
12-10-2023 12:21 PM
Hi @Leftz ,
Although the Simulator is called an ACI Simulator, it is probably better described as an APIC Simulator - but the APIC it simulates has been pre-programmed with a leaf-spine topology with ports. But the leaves and spine and ports do not exist, so there can never be an endpoint seen on an EPG.
Also, check @Robert Burns' contributions to this thread for some more explanations about how the Simulator works.
12-10-2023 12:11 PM
12-10-2023 12:21 PM
Hi @Leftz ,
12-10-2023 08:10 PM - edited 12-10-2023 08:17 PM
Thanks RedNectar!
Can you share the partner you recommended in that thread for ACI practice?
12-10-2023 09:17 PM
Hi @Leftz ,
Thanks RedNectar!
Since you asked, I guess it's OK to share: Housley Communications. www.housley.com.au - but there are many other great providers that may service your region.
12-11-2023 03:54 PM
Thanks!
