ACI - Topology - Map not correctly refreshed after Apic moving
ju.mahieu
Version: 2.1(1h)
Our apic3 was previously connected to our Leaf 101 and 102.
Yesterday, this Apic3 was moved to a new building and connected to leaf 103/104.
Apic3 is not anymore connected to the leaf 101/102.
Apic3 has been correctly discovered and added to the fabric as a fully fit controller :-)
Unfortunately, the topological map was not correctly refreshed and the former connections to leaf 101/102 are still present... and also the new ones towards the leaf 103/104 (See below).
Maybe a cosmetic issue ? How could I solve this problem.
Below the lldp information :
apic3# fabric 101 show lldp neighbors
 Node 101 (leaf101)
Device ID            Local Intf      Hold-time  Capability  Port ID
apic2           Eth1/47         120                    eth2-1
apic1           Eth1/48         120                    eth2-1
spine201        Eth1/49         120        BR          Eth1/1
apic3# fabric 103 show lldp neighbors
 Node 103 (leaf103)
apic3           Eth1/48         120                    eth2-2
spine201        Eth1/49         120        BR          Eth1/3
apic3# fabric 104 show lldp neighbors
 Node 104 (leaf104)
apic3           Eth1/48         120                    eth2-1
spine202        Eth1/50         120        BR          Eth1/4
gmonroy
ju.mahieu,
   You may be affected by the following known bug:
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvc76776/?reffering_site=dumpcr
In summary:
  • Issue should be cosmetic
  • TAC is required to remove the stale objects
Cheers,
Gabriel
gmonroy
ju.mahieu,
In summary:
Cheers,
Gabriel
Thank you Gabriel for this quick answer.
Ju
