ACI / Traffic going from EPG to ESG in a different VRF is blocked
MarceloBF
Hello Guys
I am trying to implement vrf route leaking using ESGs. If you check the attached diagram my goal is to bypass the flow going through the firewall when all the endpoints in EPG_VLAN200 want to communicate with especific endpoints in EPG_VLAN100. Any other traffic (for both EPGs)  must go through the firewall (interVRF).
The need to use ESGs is because:
1. We can't apply a contract to an ESG and EPG at the same time.
2. We need to leak traffic from and to specific endpoints in EPG_VLAN100
So, I have configured two ESGs:
1. ESG_VLAN100 contains especific IP address selectors
2. ESG_VLAN200 contains the EPG_VLAN200 as selectors
3. I have created a contract with the default filter and tenant as scope and I have applied the contract as consumed by ESG_VLAN100 and as provided by ESG_VLAN200.
4. Under each VRF I have configured InterVRF Leaked Routes for ESG to accomplish my goal (bypass the traffic).
5. I have a vzAny contract (consumed/provided). This configuration is applied both to vrf Blue and vrf Red.
Under these circumstances, the vrf route leaking works as expected, however when the endpoints in EPG_VLAN201 (vrf Red) wants to communicate with the especific endpoints in ESG_VLAN100 (vrf Blue) the traffic is denied. The same happens when the endpoints in EPG_VLAN101 (vrf Blue) want to communicate with the endpoints in ESG_VLAN200 (vrf Red).
 Looking forward for your comments. Thanks in advance.
6 Replies 6
AshSe
Hey @MarceloBF
I have tried to recreate the diagram (inserted below):
could you please elaborate the significance of the contracts and arrows shown by you in your diagram.
BR
AshSe
Hello AshSe
I see some incorrect information in your diagram. ESG_VLAN100 and ESG_VLAN200 are linked to endpoints in different subnets, plus unlike ESG_VLAN100, ESG_VLAN200 is using EPG Selectors. About the contract, this is provided by the ESG_VLAN200 (VRF RED) and consumed by the ESG_VLAN100(VRF_BLUE), it is using the default filter (permit any).
The goal is to leak the traffic between enpoints ESG_VLAN100 and endpoints in ESG_VLAN200.
Any other traffic, for example: traffic between enpoints in EPG_VLAN201 (VRF_RED) and endpoints in ESG_VLAN101 (VRF_BLUE) must use the L3out connection. I have made elam captures and I have noticed that this traffic is trying to be leaked as well (pctag 14 0xE).
updated
julian.bendix
Level 4
Level 4
Hey @MarceloBF !
Could you share more details on the output of the ELAM you ran?
Did it show the traffic as dropped, if yes, what does it show as reason (drop code)?
Other than that, if the config is like shown in the diagram, it looks fine to me.
BR Jules
Hello Julian ,
Actually this issue was escalated to the tac, because I don't see the error in the configuration. The output refers to an endpoint in an EPG in VRF_RED trying to reach an endpoint in ESG in VRF_BLUE. The output shows that there is no contract applied (there is a vzAny in VRF_RED, just in case)
Contract Lookup Key
IP Protocol : TCP( 0x6 )
L4 Src Port : 65214( 0xFEBE )
L4 Dst Port : 22( 0x16 )
sclass (src pcTag) : 49161( 0xC009 )
dclass (dst pcTag) : 14( 0xE )
src pcTag is from local table : yes
derived from a local table on this node by the lookup of src IP or MAC
Unknown Unicast / Flood Packet : no
If yes, Contract is not applied here because it is flooded
Contract Result
Contract Drop : yes
Contract Logging : yes
Contract Applied : no
Contract Hit : yes
Contract Aclqos Stats Index : 81569
( show sys int aclqos zoning-rules | grep -B 9 "Idx: 81569" )
Hey @MarceloBF !
Sounds like something I would escalate to Cisco TAC at this point too.
Thanks for the Info, would be awesome if you could share the outcome.
Anyways I'd be glad to help if you run into other issues!
BR
Jules
