APIC controller Storage issue
we did replaced the SSD Storage and APIC reseted so now all runs well as per this:
 but why the storage percentage is still different after a week on the clusters ?
thanks and regards
7 Replies 7
ecsnnsls
Please contact TAC
Robert Burns
Try uploading an image (Controller or Switch).  The used % should be reduced on all controllers.  I don't believe the firmware partition will be re-sync'd unless the controller was removed compeltely from the fabric and re-added.  But any new images added should be replicated to all controllers.  Simply swapping the SSD alone, and reseting the controller (without Decomissioning it) will not force a re-sync.
Robert
Hi Robert, may i upload any image version? I have these only aci-apic-dk 9.4.2s.iso and aci-apic-dk 9.4.2l.iso
Yes, test with any image that does NOT yet exist on the APIC (hasn't been previously uploaded).
Robert
we have first tried to rename a file and upload it  didn't work. then deleted the newer version which we had already uploaded and uploaded it again. Now the load shows the same numbers, just APIC 01 changed position;
Robert Burns
Great.  So all three controllers now show the same storage levels correct?
Robert
this is how it was before:
and this is now, after upload of the image:
i was thinking that numbers should be equal ?
