02-26-2022 12:17 PM
Hello Community,
I created a small ACI Lab and finally I found an old APIC-M2.
According to the BIOS, the TPM module is owned.
However, if I start the installation of the APIC, the installation fails.
As soon as I disable the TPM and install version 4.0(3d), the APIC boots and I can update to version 4.2(7r) with the TPM enabled.
Now I have connected my Leaf and Spine switches (LLDP on VIC disabled and CIMC dedicated) these are detected and the switch goes to inactive state after a short time.
All settings look good so far.. Except for the certificate of the APIC.. This reports an error during the certificate check as well and the error F3031.
I assume that this is why the switches will be switched to inactive.
What options do I have to renew this certificate? I assume that unfortunately the certificate on the TPM is defective here.
Unfortunately, I do not have a valid service contract for the APIC.
I hope you can help me.
Thank you!
02-27-2022 04:53 AM
