Cisco ACI 5.1 NSX-T integration
Just read there is new integration available with NSX-T SDN controller from ACI version 5.1.
Cisco ACI and VMware NSX-T Data Center Integration - Cisco
Besides this there is not a lot of information available for this.  Is there any good reference architecture for the combination NSX-T and ACI.  My personal opinion would be choose one or the other to reduce complexity.
Main purpose at customer site is now micro-segmentation is done via NSX-T.
Any reference articiles info would be good.
11 Replies 11
Sergiu.Daniluk
Hi @Frederik De Muyter
There is the one from VMware. Find it attached.
Stay safe,
Sergiu
thank you already had that one.  The new version 5.1 realy integrates the NSX-T controller.  If my understating is correct this actually pushes aci objects to NSX-T.   For example EPG --> to Segment in NSX-T.
Could it be that this approach uses VLAN backed transport zones on NSX-T.
Approach 1: (i am intrested in this also)
This means ACI handles the networking while NSX provides distributed firewall functionality. Until recently, the single overlay design was the most frequently implemented architecture of NSX on ACI.
Approach 2: (this is what the document from vmware is talking about)
The other method is utilizing a double overlay. ACI would provide an overlay and security for workloads not being managed by NSX-T. NSX-T runs on top of the ACI fabric but has its own overlay for networking while using ACI's overlay as the transport. NSX-T then peers with ACI using BGP or static routes by connecting the NSX Edge to an ACI border leaf. This peering allows the enterprise network to access NSX-T resources through the ACI fabric.
This video should help you as well. It leverages VLAN-based transport zone on NSX-T for the virtual networking integration in ACI.
In this chapter we will cover how ACI integration to VMware NSX-T brings value to both network and vm-admins, how it works, what happens automatically behind the scenes and how to configure it
Hi,Just read Cisco ACI and VMware NSX-T Data Center Integration - Cisco
Q1: Is it right that currently the integration only supports vlan based connectivity. Connections based on VXLAN are not suppported?
or is already supports.
Q2: How long is it expected to support, do you know ?
How we deployed it: We had L3out with BGP peering to NSX-T Tier 1 routers. ACI would act as transit to the Core Routers.
Hi @Sergiu.Daniluk ,
it seems to be to document is only for NSX-V. Maybe there is anything like this for NSX-T.
BR
Udo
HI,
There are some links and youtube videos referenced above.
Cheers,
Sergiu
Mayday05
Hi Mayday,
the integration works the same as normall VMM integration so inside the fabric it will be VXLAN transport. The transport nodes will not use Genève as an underlay and You will have no edge nodes on NSX-T side. So you will only use firewall part off NSX-T but this is the Main raison people buy IT i guess.
ACI network team manages the networks and not the vmware team.  Starting from NSX-T 3.0 EVPN is also supporter on edge nodes using vrf lite.
https://nsx.ninja/index.php/NSX-T_EVPN_North/South_routing_with_NX-OS_EVPN-based_Datacenter_fabric
But this is for another use case.
Hope this info can help You and i would say try It out in a lab that is what I did.
Frederik
 thanks ,what i means is whether the latst apic support create the overlay type transport zone witn nsx-t。 the 5.1 version is not support。
udo.konstantin
Hello, does anyone know if VCF is supported while integrating NSX-T into ACI?
