cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
Respuestas
Cisco ACI migrosegmentation network base attributes
zulkarnain
Hi All.
Is there anyway to make the network base attributes in ACI microsegmentation using ip range rather than single ip? Let's say in the epg I have a range of IP 10.1.1.100 - 10.1.1.200 to be include inside the attributes. In normal config I have to put the all the IP 10.1.1.100, 10.1.1.101 and so on until 10.1.1.200. Please help.
2 RESPUESTAS 2
BANERJEE SHIBASISH
Hi @zulkarnain
You can apply one or more MAC or IP addresses to a uSeg EPG. For IP addresses, you simply specify the address or the subnet.
To know more about Network-Based Attributes for Micro-segmentation with Cisco ACI, please follow below link.
https://www.cisco.com/c/en/us/td/docs/dcn/aci/apic/5x/virtualization-guide/cisco-aci-virtualization-guide-52x/m-microsegmentation.html#concept_D527CF389D4440E69A288093516B3643
Shibasish
Hi @zulkarnain
If you find my reply solved your question or issue, kindly click the 'Accept as Solution' button and vote it as helpful.
You can also learn more about Cisco ACI through our live Ask the Experts (ATXs) session. Check out the ATXs Resources [https://community.cisco.com/t5/data-center-and-cloud-knowledge/cisco-aci-ask-the-experts-resources/ta-p/4394491] to view the latest schedule for upcoming sessions, as well as the useful references, e.g. online guides, FAQs.
Shibasish
