CLI login issue for the APIC controller
Unable to login to the APIC controller from SSH. We got the error below.
XXXXXX:~$ ssh -l  ACxxx  192.x.x.x.
Application Policy Infrastructure Controller
acxx@192.x.x.x's password:
[Errno -3] Temporary failure in name resolution.
^C^C
^C^C
ADP-89
Hello @Jothiprakash.S5886 ,
I have seen this in the past.
An APIC reload solves the problem. If you do not want to reload the APIC you might need to call TAC and ask them to restart the ssh daemon via root user.
Hope that helps,
ADP
   Thanks for your revert. Is there any documents for this
ADP-89
AFAIK there is not a document describing such behaviour and related solution.
If you would like a deeper analysis and a supported resolution/workaround I suggest you to open a TAC case.
ADP
