configure cisco out of band for Cisco ACI
monasir
Hi all,
Can anyone help me out with configuring Cisco out of band switch in case your not able to control/manage the Cisco apic environment.
We would like to use a Cisco 3560 switch which is connected to one of the leafe's.
Any help would be appreciated!
RedNectar
Hi @monasir ,
Your configuration is pretty straight-forward.  I have a similar configuration on a 3750 switch
My OOB subnet is 172.16.11.0/24, and the default gateway is a 2950 Router with IP of 172.16.11.1.  I am using VLAN 1000 for my OOB VLAN.
The switch has the following (relevant) configuration:
interface GigabitEthernet1/0/41
 description =>APIC1
 switchport access vlan 1000
 switchport mode access
interface GigabitEthernet1/0/42
 description =>APIC2
interface GigabitEthernet1/0/43
 description =>APIC3
interface GigabitEthernet1/0/44
 description =>Spine201-
interface GigabitEthernet1/0/45
 description =>Spine202
interface GigabitEthernet1/0/46
 description =>Leaf101
interface GigabitEthernet1/0/47
 description =>Leaf102
interface Vlan1000
 ip address 172.16.11.37 255.255.255.0
ip default-gateway 172.16.11.1
ip http server
ip http secure-server
ip route 0.0.0.0 0.0.0.0 172.16.11.1
I hope this helps
Don't forget to mark answers as correct if it solves your problem. This helps others find the correct answer if they search for the same problem
RedNectar aka Chris Welsh.
