06-07-2017 06:32 AM - edited 03-01-2019 05:15 AM
Which ACI software release version would fix the issue below?
Solved! Go to Solution.
06-07-2017 06:39 AM
This bug is not yet resolved. Once it is, the integrated releases will be populated.
Robert
06-07-2017 06:39 AM
Robert
12-07-2017 03:46 PM
Before APIC, release 2.3(1f), transit routing was not supported within a single L3Out profile. In APIC, release 2.3(1f) and later, you can configure transit routing with a single L3Out profile, with the following limitations:
The external documentation was also updated yesterday by the doc team
The enhancement bug CSCuy16355 is also updated with above details, please feel free to check out.
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCuy16355/?reffering_site=dumpcr
12-13-2017 06:55 AM
This is great news! Is this also fixed in ACI 3.0 and, if so, which versions?
-Craig
12-13-2017 10:51 PM - edited 12-13-2017 10:57 PM
Craig, transit routing within single l3out would work in any release later than 2.3(1f) with above workaround applied, and it's supported. HTH.
