Delete Stale Loose Node
nelsbrow
I have a stale loose node that I'd like to delete.  The device is no longer in the network, but still shows up in the APIC under /home/admin/mit/topology.  I tried deleting it using modelete and 'moconfig commit', and aside from the warning that those commands are deprecated and to use the NX-OS style command, it seems they also are unable to delete that object.
Any advice on the current way to do this is appreciated.  Thanks.
dpita
Hello
What version of ACI are you running? Usually this will require a TAC case to resolve. how long ago was the device removed from ACI?
2.2(1n).  It's been 3 days now, so it's not just a question of a timeout.
Cisco will have to either fix this or provide a mechanism for the customers to deal with it.  Devices get powered off or reconfigured all the time.  I can't have someone call TAC every time that happens.
