08-31-2023 04:01 AM
We deployed ova file according to manual and can't reach oob interfaces from outside no matter how topology was deployed. Maybe there are something misconfiguration from scratch or we missed some point through ova deployment. Is there any manual with installation on vCenter.
Krzysztof Sk.
Solved! Go to Solution.
08-31-2023 02:04 PM
Hi @krzysztof sk ,
I know you said you "deployed ova file according to manual" - but can you double check that you DID NOT CHANGE ANY DEFAULT VALUES when you first booted up the sim - with the exception of the OOB IP address/mask/gateway
Also, check vCentre - are the interfaces of the Sim
08-31-2023 02:04 PM
Hi @krzysztof sk ,
09-01-2023 03:03 AM
Thanks, we've probably missed portgroup confgiuration. Is it special configuration of mensioned portgroup or made by default?
BR.
Krzysztof Skowron
09-02-2023 05:39 PM
@krzysztof sk how did you fix the issue?
