MIBs for ACI APIC Release 5.2(4e)
reyesluis96
I have been looking for the MIBs supported for ACI release 5.2(4e) that has the following images:
  • aci-apic-dk9.5.2.4e.iso
  • aci-n9000-dk9.15.2.5e.bin
The only document that I found, is for Release 4.2(3).
Please, let me know if someone can help me with this.
Thanks.
Sergiu.Daniluk
Hi @reyesluis96
Take a look here:
https://www.cisco.com/c/dam/en/us/td/docs/Website/datacenter/aci/mib/mib-support.html
The same MIB list is for newer versions as well.
Cheers,
Sergiu
Thank you for your response, but this document is for the Cisco APIC Release 4.2(3).
Hi @reyesluis96 ,
Note that the reference @Sergiu.Daniluk gave was last revised 8 June 2022.
If there are elements that you were expecting in ACI release 5.2(4e) that are not present in the current list (as given at https://www.cisco.com/c/dam/en/us/td/docs/Website/datacenter/aci/mib/mib-support.html then you should send email to apic-docfeedback@cisco.com.
RedNectar aka Chris Welsh.
