Multipod BGP next-hop not showing
Steev112
Dears,
I established multipod between DC and DR, and i tried to verify the configuration and output i found that when i go to spine --- protocol --- bgp --- next-hop, id didn't any ip addess on next-hop, however if i connect any pc in dc and dr is pinging?
how can i solve this issue? or this is normal.
ranraju
Can you please share the outputs of the show commands that you are looking at on the spine?
ranraju
Hi Ranraju,
Thanks for reply, the issue is solved.
Thanks again
ahmad123456
hi, I have the same problem, how did u fix it?
