Multisite and Shared L3OUT
apache_le
Would Mutlisite support Shared L3OUT configured in common tenant in each of the Site?  What version of APIC and Multisite support this feature?  Thanks.
Alejandro AP .:|:.:|:.
Hi @apache_le ,
There is no current release that support this. Its in our road map  to get it as a new feature but as far as now it is not possible.
Alejandro Avila Picado .:|:.:|:.
Shared L3out are supported with multisite
peterzhang
If you have all BDs/VRFs/L3Outs configured in Tenant common and only EPGs in application Tenants. it's not considered "shared". It's shared when you require "inter-VRF" communication
Currently shared L3Out is supported (4.0)
Transit L3out is also now supported (4.2)
However, there are also caveats to both setups. Make sure you fully understand and tested out the caveats before deployment
When I replied to this threat first time , I understood that you were trying to do what we do support now in 4.2 and MSO 2.2(1).
ACI Multi-Site now supports a number of scenarios in which a single L3Out can be shared between multiple sites.
For more information, see Intersite L3Out section in the “Schema Management” chapter of the Cisco ACI Multi-Site Configuration Guide, Release 2.2(x).
And as mentioned before this was going to be  new feature called Intersite L3Out.
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/aci/aci_multi-site/sw/2x/release-notes/Cisco-ACI-Multi-Site-Release-Notes-221.html
