New APIC-M4 (C225 M6 chassis) not showing a VIC / adapter 1 in CIMC
vv0bbLeS
Hello all,
I have a new APIC-M4 (C225-M6 chassis) that I'm installing, and I wanted to upgrade the software on it to the new 6.0.5(M) version, but before doing that I went to upgrade the CIMC version to the recommended version for 6.0.5(M). Per the Cisco Application Policy Infrastructure Controller Release Notes, Release 6.0(5) - Cisco , the CIMC version depends on whether you have a certain SFP connector on your Adapter 1:
 4.3.2.230207 CIMC HUU ISO (recommended*) for UCS C220/C240 M5 (APIC-L3/M3) and UCS C225 M6 (APIC-L4/M4)
* We do not recommend this CIMC release if you have the SFP-10G-T-X connector type on the Cisco APIC data link ports (eth2-1 and eth2-2). To see which connector type you have, enter commands as shown in the following example:
C220-WMP2704001H /chassis # scope adapter 1
C220-WMP2704001H /chassis/adapter # show ext-eth-if detail
So I went into my APIC-M4 CIMC to run those commands, and I discovered I don't have an adapter 1 :
apic2-cimc# scope chassis
apic2-cimc /chassis #
apic2-cimc /chassis # scope adapter 1
Error: Managed object does not exist, use show command to list valid targets
apic2-cimc /chassis # show ad
adapter            adapter-ie-status
apic2-cimc /chassis # show adapter
Is this a problem to not show an "adapter 1" in my chassis ?
0xD2A6762E
Robert Burns
Pro-tip - Next time drop the output into a txt file and attach that, so it doesn't blow out the thread
So your adapter is the Intel 10/25G SFP adapter, so you can ignore the HUU warning and proceed.  Let the Host Update Utility update everything it can.
UCSC-P-I8D25GF
 Robert
8 Replies 8
Robert Burns
Provide the output of:
scope chassis
inventory-all
Robert
Thanks Robert, please see output below:
apic2-cimc#
apic2-cimc /chassis # inventory-all
sysProductName: APIC-SERVER-M4
sysProductID: APIC-SERVER-M4
sysSerialNum: WZP272700PZ
localTime: Thu Mar 28 21:03:36 2024 UTC +0000 (Local)
CPU
  SocketDesignation: CPU1
  ProcessorManufacturer: Advanced Micro Devices, Inc.
  ProcessorFamily: Zen
  ThreadCount: 32
  SerialNumber: Unknown
  ProcessorVersion: AMD EPYC 7313P 16-Core Processor
  CurrentSpeed: 3000
  CoreCount: 16
  CoreEnabled: 16
  Status: Enabled
  MaxSpeed: 3725
  Signature: Family 19h, Model 1, Stepping 1
  SocketDesignation: CPU2
  ProcessorManufacturer: N/A
  ProcessorFamily: N/A
  ThreadCount: N/A
  SerialNumber: N/A
  ProcessorVersion: N/A
  CurrentSpeed: N/A
  CoreCount: N/A
  CoreEnabled: N/A
  Status: Unpopulated
  MaxSpeed: N/A
  Signature: N/A
Memory
DIMMList:
  Capacity: Not Installed
  Speed: NA
  MemoryType: NA
  MemoryTypeDetail: NA
  BankLocator: NA
  Manufacturer: NA
  SerialNumber: NA
  AssetTag: NA
  PartNumber: NA
  Visibility: NA
  Operability: NA
  DataWidth: NA
  Capacity: 16384 MB
  Speed: 3200
  MemoryType: DDR4
  MemoryTypeDetail: Synchronous Registered (Buffered)
  BankLocator: NODE 0 CHANNEL 0 DIMM 1
  Manufacturer: 0xAD00
  SerialNumber: E057CCD1
  AssetTag: Not Specified
  PartNumber: HMA82GR7DJR4N-XN
  Visibility: Yes
  Operability: Operable
  DataWidth: 64 bits
  Speed: NA
  MemoryType: NA
  BankLocator: NA
  Manufacturer: NA
  SerialNumber: NA
  AssetTag: NA
  PartNumber: NA
  Visibility: NA
  Operability: NA
  DataWidth: NA
  Speed: NA
  MemoryType: NA
  BankLocator: NA
  Manufacturer: NA
  SerialNumber: NA
  AssetTag: NA
  PartNumber: NA
  Visibility: NA
  Operability: NA
  DataWidth: NA
  Speed: NA
  MemoryType: NA
  BankLocator: NA
  Manufacturer: NA
  SerialNumber: NA
  AssetTag: NA
  PartNumber: NA
  Visibility: NA
  Operability: NA
  DataWidth: NA
  Capacity: 16384 MB
  Speed: 3200
  MemoryType: DDR4
  BankLocator: NODE 0 CHANNEL 2 DIMM 1
  SerialNumber: E057CC6C
  Visibility: Yes
  DataWidth: 64 bits
  Speed: NA
  MemoryType: NA
  BankLocator: NA
  Manufacturer: NA
  SerialNumber: NA
  AssetTag: NA
  PartNumber: NA
  Visibility: NA
  Operability: NA
  DataWidth: NA
  Capacity: 16384 MB
  Speed: 3200
  MemoryType: DDR4
  BankLocator: NODE 0 CHANNEL 3 DIMM 1
  SerialNumber: E057CCD2
  Visibility: Yes
  DataWidth: 64 bits
  Speed: NA
  MemoryType: NA
  BankLocator: NA
  Manufacturer: NA
  SerialNumber: NA
  AssetTag: NA
  PartNumber: NA
  Visibility: NA
  Operability: NA
  DataWidth: NA
  Capacity: 16384 MB
  Speed: 3200
  MemoryType: DDR4
  BankLocator: NODE 0 CHANNEL 4 DIMM 1
  SerialNumber: E057CC96
  Visibility: Yes
  DataWidth: 64 bits
  Speed: NA
  MemoryType: NA
  BankLocator: NA
  Manufacturer: NA
  SerialNumber: NA
  AssetTag: NA
  PartNumber: NA
  Visibility: NA
  Operability: NA
  DataWidth: NA
  Speed: NA
  MemoryType: NA
  BankLocator: NA
  Manufacturer: NA
  SerialNumber: NA
  AssetTag: NA
  PartNumber: NA
  Visibility: NA
  Operability: NA
  DataWidth: NA
  Speed: NA
  MemoryType: NA
  BankLocator: NA
  Manufacturer: NA
  SerialNumber: NA
  AssetTag: NA
  PartNumber: NA
  Visibility: NA
  Operability: NA
  DataWidth: NA
  Capacity: 16384 MB
  Speed: 3200
  MemoryType: DDR4
  BankLocator: NODE 0 CHANNEL 6 DIMM 1
  SerialNumber: E057CCE6
  Visibility: Yes
  DataWidth: 64 bits
  Speed: NA
  MemoryType: NA
  BankLocator: NA
  Manufacturer: NA
  SerialNumber: NA
  AssetTag: NA
  PartNumber: NA
  Visibility: NA
  Operability: NA
  DataWidth: NA
  Capacity: 16384 MB
  Speed: 3200
  MemoryType: DDR4
  BankLocator: NODE 0 CHANNEL 7 DIMM 1
  SerialNumber: E057CCAE
  Visibility: Yes
  DataWidth: 64 bits
  Speed: NA
  MemoryType: NA
  BankLocator: NA
  Manufacturer: NA
  SerialNumber: NA
  AssetTag: NA
  PartNumber: NA
  Visibility: NA
  Operability: NA
  DataWidth: NA
  Speed: NA
  MemoryType: NA
  BankLocator: NA
  Manufacturer: NA
  SerialNumber: NA
  AssetTag: NA
  PartNumber: NA
  Visibility: NA
  Operability: NA
  DataWidth: NA
  Speed: NA
  MemoryType: NA
  BankLocator: NA
  Manufacturer: NA
  SerialNumber: NA
  AssetTag: NA
  PartNumber: NA
  Visibility: NA
  Operability: NA
  DataWidth: NA
  Speed: NA
  MemoryType: NA
  BankLocator: NA
  Manufacturer: NA
  SerialNumber: NA
  AssetTag: NA
  PartNumber: NA
  Visibility: NA
  Operability: NA
  DataWidth: NA
  Speed: NA
  MemoryType: NA
  BankLocator: NA
  Manufacturer: NA
  SerialNumber: NA
  AssetTag: NA
  PartNumber: NA
  Visibility: NA
  Operability: NA
  DataWidth: NA
  Speed: NA
  MemoryType: NA
  BankLocator: NA
  Manufacturer: NA
  SerialNumber: NA
  AssetTag: NA
  PartNumber: NA
  Visibility: NA
  Operability: NA
  DataWidth: NA
  Speed: NA
  MemoryType: NA
  BankLocator: NA
  Manufacturer: NA
  SerialNumber: NA
  AssetTag: NA
  PartNumber: NA
  Visibility: NA
  Operability: NA
  DataWidth: NA
  Speed: NA
  MemoryType: NA
  BankLocator: NA
  Manufacturer: NA
  SerialNumber: NA
  AssetTag: NA
  PartNumber: NA
  Visibility: NA
  Operability: NA
  DataWidth: NA
  Speed: NA
  MemoryType: NA
  BankLocator: NA
  Manufacturer: NA
  SerialNumber: NA
  AssetTag: NA
  PartNumber: NA
  Visibility: NA
  Operability: NA
  DataWidth: NA
  Speed: NA
  MemoryType: NA
  BankLocator: NA
  Manufacturer: NA
  SerialNumber: NA
  AssetTag: NA
  PartNumber: NA
  Visibility: NA
  Operability: NA
  DataWidth: NA
  Speed: NA
  MemoryType: NA
  BankLocator: NA
  Manufacturer: NA
  SerialNumber: NA
  AssetTag: NA
  PartNumber: NA
  Visibility: NA
  Operability: NA
  DataWidth: NA
  Speed: NA
  MemoryType: NA
  BankLocator: NA
  Manufacturer: NA
  SerialNumber: NA
  AssetTag: NA
  PartNumber: NA
  Visibility: NA
  Operability: NA
  DataWidth: NA
  Speed: NA
  MemoryType: NA
  BankLocator: NA
  Manufacturer: NA
  SerialNumber: NA
  AssetTag: NA
  PartNumber: NA
  Visibility: NA
  Operability: NA
  DataWidth: NA
  Speed: NA
  MemoryType: NA
  BankLocator: NA
  Manufacturer: NA
  SerialNumber: NA
  AssetTag: NA
  PartNumber: NA
  Visibility: NA
  Operability: NA
  DataWidth: NA
  Speed: NA
  MemoryType: NA
  BankLocator: NA
  Manufacturer: NA
  SerialNumber: NA
  AssetTag: NA
  PartNumber: NA
  Visibility: NA
  Operability: NA
  DataWidth: NA
  Speed: NA
  MemoryType: NA
  BankLocator: NA
  Manufacturer: NA
  SerialNumber: NA
  AssetTag: NA
  PartNumber: NA
  Visibility: NA
  Operability: NA
  DataWidth: NA
HDD
LocalHardDiskList:
  Disk: 5
  Controller: MRAID
  Description: 480GB 2.5in Enterprise performance 6G SATA SSD (3X endurance)
  PID: UCS-SD480GM3X-EP
  Vendor: ATA
  Model: Micron_5300_MTFDDAK480TDT
  SerialNumber: 22453E681638
  powMin: 6
  powMax: 6
  Disk: 6
  Controller: MRAID
  Description: 960GB 2.5in Enterprise performance 6G SATA SSD (3X endurance)
  PID: UCS-SD960G63X-EP
  Vendor: ATA
  Model: INTEL SSDSC2KG960GZK
  SerialNumber: BTYJ244601LM960BGN
  powMin: 0
  powMax: 0
  Disk: 253
  Controller: MSTOR-RAID
  Description: 240GB SATA M.2
  PID: UCS-M2-240GB
  Vendor: ATA
  Model: Micron_5300_MTFDDAV240TDS
  SerialNumber: MSY26171HXD
  powMin: 6
  powMax: 6
PCI
  Slot: 1
  PID: UCSC-P-I8D25GF
  VendorID: 0x8086
  DeviceID: 0x159b
  SubVendorID: 0x1137
  SubDeviceID: 0x02be
  OptionROMLoaded: 0
  ProductName: Cisco - Intel E810XXVDA2 2x25/10 GbE SFP PCIe NIC
  fwVersion: 0x8000AA76-1.826.0
  Slot: MRAID
  PID: UCSC-RAID-M6T
  VendorID: 0x1000
  DeviceID: 0x10e2
  SubVendorID: 0x1137
  SubDeviceID: 0x02a4
  OptionROMLoaded: 0
  ProductName: Cisco 12G SAS RAID Controller with 4GB FBWC (16 Drives)
  fwVersion: 52.20.0-4523
  Slot: MLOM
  PID: UCSC-O-ID10GC
  VendorID: 0x8086
  DeviceID: 0x15ff
  SubVendorID: 0x1137
  SubDeviceID: 0x02d9
  OptionROMLoaded: 0
  ProductName: Cisco(R) X710T2LG 2x10 GbE RJ45 OCP 3.0 NIC
  fwVersion: 0x8000B906-1.826.0
  Slot: MSTOR-RAID
  PID: UCS-M2-HWRAID
  VendorID: 0x1b4b
  DeviceID: 0x9230
  SubVendorID: 0x1137
  SubDeviceID: 0x0251
  OptionROMLoaded: 0
  ProductName: Cisco Boot optimized M.2 Raid controller
  fwVersion: 2.3.17.1014
Power Supplies
  deviceID: PSU1
  Status: Present
  Status2: equipped
  InputWatt: 70
  Power: on
  OutputMaxWatt: N/A
  OutputWatt: 54
  fwVersion: 10252046
  Model: 700-014550-0000
  MfgRev: CT
  ProductID: UCSC-PSU1-1050W
  deviceID: PSU2
  Status: Present
  Status2: equipped
  InputWatt: 66
  Power: on
  OutputMaxWatt: N/A
  OutputWatt: 52
  fwVersion: 10252046
  MfgRev: CT
Fan status
  sensorStatus: Unavailable
  reading: N/A
  units: RPM
  minWarning: N/A
  maxWarning: N/A
  minFailure: N/A
  maxFailure: N/A
  minNR: N/A
  maxNR: N/A
  reading: N/A
  units: RPM
  minWarning: N/A
  maxWarning: N/A
  minFailure: N/A
  maxFailure: N/A
  minNR: N/A
  maxNR: N/A
  reading: N/A
  units: RPM
  minWarning: N/A
  maxWarning: N/A
  minFailure: N/A
  maxFailure: N/A
  minNR: N/A
  maxNR: N/A
  reading: N/A
  units: RPM
  minWarning: N/A
  maxWarning: N/A
  minFailure: N/A
  maxFailure: N/A
  minNR: N/A
  maxNR: N/A
  reading: N/A
  units: RPM
  minWarning: N/A
  maxWarning: N/A
  minFailure: N/A
  maxFailure: N/A
  minNR: N/A
  maxNR: N/A
  reading: N/A
  units: RPM
  minWarning: N/A
  maxWarning: N/A
  minFailure: N/A
  maxFailure: N/A
  minNR: N/A
  maxNR: N/A
  reading: N/A
  units: RPM
  minWarning: N/A
  maxWarning: N/A
  minFailure: N/A
  maxFailure: N/A
  minNR: N/A
  maxNR: N/A
  reading: N/A
  units: RPM
  minWarning: N/A
  maxWarning: N/A
  minFailure: N/A
  maxFailure: N/A
  minNR: N/A
  maxNR: N/A
  reading: N/A
  units: RPM
  minWarning: N/A
  maxWarning: N/A
  minFailure: N/A
  maxFailure: N/A
  minNR: N/A
  maxNR: N/A
  reading: N/A
  units: RPM
  minWarning: N/A
  maxWarning: N/A
  minFailure: N/A
  maxFailure: N/A
  minNR: N/A
  maxNR: N/A
  reading: N/A
  units: RPM
  minWarning: N/A
  maxWarning: N/A
  minFailure: N/A
  maxFailure: N/A
  minNR: N/A
  maxNR: N/A
  reading: N/A
  units: RPM
  minWarning: N/A
  maxWarning: N/A
  minFailure: N/A
  maxFailure: N/A
  minNR: N/A
  maxNR: N/A
  reading: N/A
  units: RPM
  minWarning: N/A
  maxWarning: N/A
  minFailure: N/A
  maxFailure: N/A
  minNR: N/A
  maxNR: N/A
  reading: N/A
  units: RPM
  minWarning: N/A
  maxWarning: N/A
  minFailure: N/A
  maxFailure: N/A
  minNR: N/A
  maxNR: N/A
  reading: N/A
  units: RPM
  minWarning: N/A
  maxWarning: N/A
  minFailure: N/A
  maxFailure: N/A
  minNR: N/A
  maxNR: N/A
  reading: N/A
  units: RPM
  minWarning: N/A
  maxWarning: N/A
  minFailure: N/A
  maxFailure: N/A
  minNR: N/A
  maxNR: N/A
tpm:
 tpmPresence: equipped
 enabledStatus: enabled
 tpmFirmareVersion: 7.85
 tpmRevision: 1
 model: UCSX-TPM2-002B-C
 vendor: Cisco Systems Inc
 serial: FCH272870A6
 version: 2.0
 activeStatus: activated
 ownership: owned
 txtPresent: Overall TXT Disabled
 txtIntelVTIssue: NA
 txtIntelVTdIssue: NA
 txtHWIssue: NA
 txtBootIssue: NA
AdapterDataList:
  Slot: MLOM
  PID: UCSC-O-ID10GC
  NoOfInterfaces: 2
  Slot: 1
  PID: UCSC-P-I8D25GF
  NoOfInterfaces: 2
Battery Status
BBUList:
  bbu:
  controller: MRAID
  group: status
  controller-type: RAID
  raid-support: yes
  battery-type: TMM-C SuperCap
  is-capacitor: true
  bbu-health: Good
  bbu-status: Optimal
  battery-present: true
  temperature: 23 degrees C
  temperature-high: false
  retention-time: N/A
  absolute-state-of-charge: N/A
  capacitance: 100 %
  charging-state: N/A
  manufacturer: LSI
  serial-number: 46276
  date: 2023-04-27
  design-voltage: 5.059 V
  voltage: 5.076 V
  current: 0.000 A
  learn-mode: Auto
  learn-cycle-status: Successful
  module-version: 180-4GB
  learn-cycle-requested: false
  next-learn-cycle: 2024-04-25 16:20
  design-capacity: 99 Joules
  relative-state-of-charge: N/A
  full-capacity: N/A
  remaining-capacity: N/A
  pack-energy: 66 Joules
  completed-charge-cycles: N/A
  BBU-temperature: 23 degrees C
  BBU-battery-present: true
  TMM-C-optimal: true
  voltage-low: false
  learn-cycle-active: false
  remaining-capacity-low: false
  no-space: false
  premium-feature-reqd: false
  microcode-upd-reqd: false
  charge-active: false
  discharge-active: false
  learn-cycle-failed: false
  learn-cycle-timeout: false
  BBU-predictive-failure: false
  BBU-replacement-required: false
  BBU-fault: false
  BBU-degraded: false
  deviceName: CVPM05
  transparentLearns: true
  BBU-capacitance: 100 %
  remaining-pool-space: 0 %
  TMM-PCB-Version-Number: 0x
  TMM-Serial-Number: 0x0000
  TMM-Manufacturing-Date: N/A
  TMM-PCB-Assembly-Number:
  TMM-Battery-Version-Number: 0x
  relearn-status: Unknown
  relearn-start-timestamp: 0
  relearn-end-timestamp: 0
  relearn-percent-complete: N/A
Adapter List
controller: MRAID
                raid-support: yes
                protocol: SAS
                typeWithSlotId: SAS-MRAID
                type-with-slotId: SAS-MRAID
                next-exec-time: 2024-03-30 03:40
                exec-freq: 7 days
                next-exec-time: N/A
                exec-freq: N/A
                pci-slot: MRAID
                managed-id: 1
                storage-status: initialized
                controller-status: Optimal
                controller-health: Good
                composite-health: Good
                overall-health: Good
                battery-status: Optimal
                controller-temperature-sensor-present: false
                ROC-temperature-sensor-present: true
                drive-temperature-supported: true
                running-on-hx: false
                controller-temperature: 255
                roc-temperature: 42
                roc-temperature-w-units: 42 degrees C
                tty-log-status: Not Downloaded
                lock-key-assigned: 0
                ctlr-secured-mgmt-type: none
                cache-is-pinned: 0
                patrol-read-operation-status: Unknown
                patrol_read_percent_complete: 0
                patrol_read_start_timestamp: 0
                patrol_read_end_timestamp: 0
                has-foreign-config: false
                foreign-config-pd-count: 0
                has-pinned-cache: false
                lost-all-config: false
                default-stripsize: 7
                default-stripe-size: 64 KB
                default-writePolicy: 0
                default-readPolicy: 0
                default-ioPolicy: 0
                writePolicy-choices: 0,1,2
                vendor: LSI Logic
                product-name: Cisco 12G SAS RAID Controller with 4GB FBWC (16 Drives)
                product-pid: UCSC-RAID-M6T
                serial-number: SKD1610496
                firmware-package-build: 52.20.0-4523
                nvram-size: 128 KB
                memory-size: 4096 MB
                flash-size: 16 MB
                cache-memory-size: 3142 MB
                bbu-status: Optimal
                min-strip-size: 7
                max-strip-size: 11
                supported-strip-sizes: 64KB, 1024KB
                ncq-status: enabled
                auto-cfg-option: unconfigured-good
                raid-transitions: |0,0|0,1|0,5|0,6|1,0|1,1|1,5|1,6|5,0|5,1|5,5|5,6|6,0|6,1|6,5|6,6|
                raid-min-pds: |0,1|1,2|5,3|6,4|
                supported-ctlr-ops: 00000e0073fffffe
                supported-phys-ops: 00000ff2effffffe
                supported-virt-ops: 000000061e7ffffe
                supported-bbu-ops: 0008
                valid-ctlr-attrs: 0000000000003ffe
                supports-cached-io: false
                supports-add-config: false
                supports-clear-config: true
                supports-disallow-force-clear-config: false
                supports-make-epd: true
                supports-trimode: false
                boot-drive: 239
                boot-drive-is-PD: false
                ctlr-treat-R1E-as-R10: false
                ctlr-bios-mode: Headless Mode
                ctlr-coercion-mode: 1GB
                ctlr-flush-time-in-seconds: 4
                ctlr-allowed-device-types: SAS/SATA Mix
                ctlr-SAS-SATA-mix-in-enclosure-allowed: true
                ctlr-SAS-SATA-mix-in-VD-allowed: true
                ctlr-SAS-SATA-SSD-mix-in-VD-allowed: true
                ctlr-SSD-HDD-mix-in-VD-allowed: false
                ctlr-disable-ctlr-R-bios: false
                ctlr-enable-web-bios: false
                ctlr-expose-enclosure-devices: true
                ctlr-maintain-PD-fail-history: false
                ctlr-max-lds-per-array: 64
                ctlr-allow-uncertified-HDDs: Allow
                ctlr-online-controller-reset-enabled: true
                ctlr-disable-cache-bypass: false
                ctlr-JBOD-mode-enabled: false
                ctlr-tty-log-in-flash-enabled: false
                ctlr-auto-enhanced-import-at-boot-enabled: true
                ctlr-use-drive-write-cache-for-rebuild-enabled: false
                ctlr-SSD-write-cache-change-blocked: true
                ctlr-HII-disabled: false
                ctlr-performance-tuner-mode: Best IOPS
                ctlr-512e-drive-support-enabled: true
                ctlr-max-VDs: 0
                ctlr-max-devices-exposed-to-legacy-BIOS: 16
                ctlr-1MB-IO-support-enabled: true
                ctlr-iMR-large-queue-depth-support-enabled: false
                ctlr-transport-ready-enabled: false
                ctlr-supports-more-than-64VDs: true
controller: MSTOR-RAID
                controller-type: M2HWRAID
                raid-support: yes
                protocol: SATA
                typeWithSlotId: SATA-MSTOR-RAID
                type-with-slotId: SATA-MSTOR-RAID
                next-exec-time: N/A
                exec-freq: N/A
                pci-slot: MSTOR-RAID
                managed-id: 2
                battery-status: BBU Not Supported
                ROC-temperature-sensor-present: false
                drive-temperature-supported: false
                controller-temperature: 0
                roc-temperature: Not Supported
                roc-temperature-w-units: Not Supported degrees C
                cache-is-pinned: 0
                default-ioPolicy: 0
                vendor: Marvell
                product-name: Cisco Boot optimized M.2 Raid controller
                product-pid: UCS-M2-HWRAID
                serial-number: FCH27277A6Y
                product-serial-no: FCH27277A6Y
                firmware-package-build: 2.3.17.1014
                nvram-size: 0 KB
                memory-size: 0 MB
                flash-size: 2 MB
                cache-memory-size: 0 MB
                bbu-status: BBU Not Supported
                min-strip-size: 6
                max-strip-size: 7
                supported-strip-sizes: 32KB, 64KB
                ncq-status: enabled
                raid-transitions: |0,0|0,1|1,0|1,1|
                supported-ctlr-ops: 000001e0000000e0
                supported-phys-ops: 0000001204000000
                supported-virt-ops: 0000000400001014
                supported-bbu-ops: 0001
                valid-ctlr-attrs: 0000000000000001
                supports-clear-config: false
                supports-make-epd: false
                boot-drive: 0
FRU Details
        BuiltinFRUDevice(ID0)
                 Chassis Type          : Rack Mount Chassis
                 Chassis Part Number   : 74-125841-01
                 Chassis Serial        : WZP272700PZ
                 Chassis Extra         : Cisco Systems Inc
                 Board Mfg             : Cisco Systems Inc
                 Board Product         : UCSC-C225-M6S
                 Board Serial          : WZP2726Z015
                 Board Part Number     : 74-125843-01
                 Board Extra           : C04V01
                 Board Extra           : 0000000000
                 Product Manufacturer  : Cisco Systems Inc
                 Product Name          : APIC-SERVER-M4
                 Product Part Number   : 74-125841-01
                 Product Version       : A0
                 Product Serial        : WZP272700PZ
                 Product Asset Tag     : Unknown
                 Product Extra         : F0V01
        FRU_FP(ID1)
                 Board Product         : UCSC-FPNL-C225M6S
                 Board Serial          : 325003D1J0A
                 Board Part Number     : FPC225M6
                 Board Extra           : A04V01
        FRU_MB(ID2)
        FRU_TPM(ID3)
                 Board Product         : UCSX-TPM2-002B-C
                 Board Serial          : FCH272870A6
                 Board Part Number     : 73-20115-01
                 Board Extra           : A03V01
        FRU_PSU1(ID4)
                 Board Product         : UCSC-PSU1-1050W
                 Board Serial          : APS271800Q6
                 Board Part Number     : 341-0638-03
                 Board Extra           : A0V03
                 Product Name          : UCSC-PSU1-1050W
                 Product Part Number   : 341-0638-03
                 Product Version       : A
                 Product Serial        : APS271800Q6
                 Product Extra         : A0V03
        FRU_PSU2(ID5)
                 Board Serial          : APS271800P2
                 Board Extra           : A0V03
                 Product Version       : A
                 Product Serial        : APS271800P2
        FRU_VIC_SLOT1(ID6)
                 Device not present (Requested sensor, data, or record not found)
        FRU_VIC_SLOT3(ID7)
        FRU_MLOM(ID8)
        FRU_HD_BP(ID9)
                 Board Product         : UCSC-HDBP-C225M6S
                 Board Serial          : 32300574J0A
                 Board Part Number     : C225SFFBP
        FRU_MINI_STORAGE(ID10)
                 Board Product         : UCS-M2-HWRAID
                 Board Serial          : FCH27277A6Y
                 Board Part Number     : 73-19532-07
                 Board Extra           : A05V02
0xD2A6762E
Robert Burns
UCSC-P-I8D25GF
 Robert
@Robert Burns  ah ok yes I can attach a txt file next time. And OK great! Thanks for looking!
0xD2A6762E
Hi, Robert, I am facing similar issue as the new M4-APIC, Admin is up, interface is up, operational state is up, but still showing switching state is disabled. I have tried to disable the LLDP in the UCS but no luck. See the inventory TX file. Putting it as a standby APIC to replace the M2 is tough in getting the switching state enabled.
@Robert Burns , any update please
Robert Burns
@jafehi000  What is your symptom? - is the new controller not seeing LLDP to/from the switch?  If that Intel 10Ge NIC came shipped with the controller there shouldn't be any configuration changes needed for it to discover.  Check if you see LLDP on both the APIC & Switch side:
From APIC:
ethtool -i eth2-1 (Your port IDs may vary slightly)
ethtool -i eth2-2
From Leaf where APIC is connected:
show lldp neighbor
Robert
@Robert Burns , see output below
apic24# ^[[200~ethtool -i eth2-1
zsh: bad pattern: ^[[200~ethtool
apic24# ethtool -i eth2-1
driver: i40e
version: 5.15.126atom-1
firmware-version: 8.50 0x8000cc10 0.386.96
expansion-rom-version:
bus-info: 0000:46:00.0
supports-statistics: yes
supports-test: yes
supports-eeprom-access: yes
supports-register-dump: yes
supports-priv-flags: yes
apic24# ethtool -i eth2-2
driver: i40e
bus-info: 0000:46:00.1
supports-test: yes
apic24#
show lldp neigboor no output. I just erased the standby apic from the controller and unable to get it working.
My plan is to replace the APIC M4 with M2 and after downgrading the M4 to 5.31d same with the M2, no luck with switching disabled. The M4 has RJ45 embedded card which requires SFP-10-TX, link profile changed for SFP 10G-TX on port 1/37 leaf switch---93180YC-EX but still no luck
