NTP is not Sync
nexus13213
I have a log fault, which says that my NTP doesn't sync.
has anyone ever experienced this?
thanks
7 Replies 7
Nik Noltenius
I have seen this temporarily after firmware upgrades but the fault always got resolved automatically after some time.
Did it work before or is this a fresh configuration?
Are you sure your NTP is reachable via OBM? Maybe a firewall blocking NTP traffic?
Nik
it's been more than a week after I upgraded, and the error is still there.
is there anything I can do to verify or to troubleshoot this issue?
and besides upgrading, I also imported configuration from ftp.
thanks
Perform on a leaf switch go into nexus shell (type vsh when logged on) and do a <show ntp statistics> and <show ntp peer-status>?
On the APIC controller go into shell mode (type bash and enter) and do <ntpq -p>, this should list your ntp peers with the status and or an indication what the issue might be.
What I have seen is that the problem might be that the ntp server you configured is unable to sync it's time (upstream ntp).
cheers
Alexander
Alexander Deca
Hi Alex,
here the output,
Leaf-201# show ntp statistics peer ipaddr 10.2.35.150
remote host:          10.2.35.150
local interface:      Unresolved
time last received:   29s
time until next send: 35s
reachability change:  73032s
packets sent:         1122
packets received:     0
bad authentication:   0
bogus origin:         0
duplicate:            1
bad dispersion:       1122
bad reference time:   0
candidate order:      0
Leaf-201#
Leaf-201# show ntp statistics peer ipaddr 10.2.35.172
remote host:          10.2.35.172
time last received:   6s
time until next send: 10s
reachability change:  73030s
packets sent:         4565
packets received:     4565
bogus origin:         0
duplicate:            3
bad dispersion:       0
candidate order:      0
Leaf-201# show ntp peer-status
Total peers : 2
* - selected for sync, + -  peer mode(active),
- - peer mode(passive), = - polled in client mode
    remote                               local                 st   poll   reach delay   vrf
=10.2.35.172                              0.0.0.0                 1   16     377   0.00053 management
=10.2.35.150                              0.0.0.0                16   64       0   0.00000 management
admin@APIC-01:~> ntpq -p
     remote           refid      st t when poll reach   delay   offset  jitter
 10.2.35.150     .INIT.          16 u   35   64    0    0.000    0.000   0.000
 10.2.35.172     .LOCL.           1 u   15   16  377    0.344  10358.7   0.286
admin@APIC-01:~>
so this isn't a problem from the apic? but from the ntp server itself which doesn't sync?
It seems your apic is unable to sync to its time server, is there a firewall in between ?
Please paste the output of ntpq -pcrv on the APIC controller?
Alexander
Alexander Deca
there is no firewall in between.
admin@APIC-01:~> ntpq -pcrv
 10.2.35.150     .INIT.          16 u    9   64    0    0.000    0.000   0.000
 10.2.35.172     .LOCL.           1 u    8   16  377    0.493  14391.5   0.060
associd=0 status=c016 leap_alarm, sync_unspec, 1 event, restart,
version="ntpd 4.2.8p10@1.3728-o Thu Aug 17 00:22:02 UTC 2017 (1)",
processor="x86_64", system="Linux/4.4.125.0.1insieme-1", leap=11,
stratum=16, precision=-24, rootdelay=0.000, rootdisp=6384.855,
refid=INIT, reftime=00000000.00000000  Thu, Feb  7 2036 13:28:16.000,
clock=dfa7ac6b.b9639adf  Tue, Nov 27 2018 18:43:39.724, peer=0, tc=3,
mintc=3, offset=0.000000, frequency=0.000, sys_jitter=0.000000,
clk_jitter=0.000, clk_wander=0.000
admin@APIC-01:~>
thanks,
I get the same problem where I get Fault F1700 and the NTP status shows my NTP server is stratum 1 with very low delay but a very high offset.
The other common factor between us is that we both have the NTP servers showing in "Polled in client mode" instead of "Selected for sync". I think we need to be "selected for sync".
My local clock is about 9 hours slow and I think that this may be reflected in the very high offset figure and I suspect that with a high offset value the APIC is refusing to trust the NTP server.
I have waited for a day now to see if ACI might start to trust the NTP server and select it for sync.. but no joy.
I have removed the NTP server config and added it back in with no joy.
