Remote Leaf VPC TEP IP Command ACI
NDP
Is there any command We can run on APIC or Leaf to find out the VTEP IP address of VPC on remote leaf
acidiag fnvread is giving us PTEP for each Fabric Node.
Hi NDP,
The command below will list the object of class fabricExplicitGEp using a filter with the attribute "virtualIp. If you are not sure about the syntax of the whole command you can always run "moquery -c fabricExplicitGEp" command without the filter, this command will list all the object under the class fabricExplicitGEp. Note that you need to run this command from the APIC.
moquery -c fabricExplicitGEp -f 'fabric.ExplicitGEp.virtualIp=="<Tunnel Destination IP ( VTEP of VPC/32>"
Also note that you can look for all of the VIP from the GUI as well.  You just need to go to Fabric>Access>Switch Policies>Policies>VPC Domain>Virtual Port channel default.
Manuel Velasco
Hi NDP,
On the Leaf node you can use:
show system internal epm vpc
Let me know if this works for you
Hi Manuel,
Wanted to know on which Leaf the VPC VTEP is residing on
suppose, there are 6 Leaf switches ( leaf1, leaf2, leaf3, leaf4, leaf5 & leaf6)
leaf 3 & leaf 4 are in one vpc domain
leaf 5 & leaf 6 are in another vpc domain
I am on leaf1 and saw that endpoint could be reached through Tunnel X, tunnel X destination is the VTEP of VPC
wanted to know what leaves are holding the Tunnel destination IP ( VTEP of VPC)
one of TAC engineer ran this "
moquery -c fabricExplicitGEp -f 'fabric.ExplicitGEp.virtualIp==" but, I forgot this
any other command, We can use .. please help me
Hi NDP,
use below command- (more easier)
moquery -c fabricExplicitGEp | grep -B10 VPC_vtep_IP
