What is the connection style from Leaf101-102 to my dual 6509-VSS , where the access switches is connected , is it L3OUT connection from ACI Prospective
Ibrahim Jamil
Level 6
Level 6
Hello Guys
gretting
thanks all
russhe
Hey Ibrahim,
It can be L2 or L3 depending on how you have it configured. What is the configuration of the interface pointing towards ACI from the 6500's point of view?
If it is an L3 interface, ACI should also be configured as L3 and then yes, an L3Out would be the appropriate matching config.
If it is an L2 configuration (i.e. trunking a VLAN), ACI could either use an L2Out or extend the EPG.
Happy to help further if you can provide some additional information.
Hello bro russhe
Thanks for ur time to reply
I attached you a Draft to give a bit info howz the ACI will be
from the dual 6509-VSS , its point to point interface
thanks
Thanks, Ibrahim. I am still unsure if this should be an L2 or an L3 connection though, the diagram does not provide any of that information. This connection could be either L2 or L3.
