ACI Contracts compression
I need to switch on contract compression in operational contracts.
1. Is it disruptive to switch contract compression on in living contracts ?
2. Do I need to erase and deploy the subjects again to have the desired impact of the compression or just turn on ?
Sergiu.Daniluk
Hi @Ulrich Vierkoetter
1. Since the contract compression basically means removing the current entries from TCAM and replacing them with a compressed version of them, most likely there will be a small impact. My suggestion is to perform the change in a controlled change window.
2. no need to deploy the subjects again. Enabling the compression is sufficient. You might also want to have a look at the guidelines and limitations related to policy compression: https://www.cisco.com/c/en/us/td/docs/switches/datacenter/aci/apic/sw/4-x/basic-configuration/Cisco-APIC-Basic-Configuration-Guide-42x/Cisco-APIC-Basic-Configuration-Guide-42x_chapter_0110.html#id_76471
Edit: regarding to point 2, the real answer is "it depends". Check the link above and you will see some specific scenarios where you will need to reapply/reconfigure the subjects.
Stay safe,
Sergiu
