441
ChrisMac70330
Beginner
ACI L3OUT using SVI.
Hi guys,
I would be interested that when doing a L3OUT with Static Routing to 2x FW with SVI , I can create 2 VPC with the same Secondary(Virtual IP node) on 2 Border leafs with the same Vlan Encapsulation.
This would be done using SVI: with the same IPs and the same vlan Encapsulation
The setup would look similar to this :
Under Logical Node Profile:
VPC 1 Side A IP 10.0.0.2/28 Side B IP : 10.0.0.3/28 Secondary IP: 10.0.0.1/28  vl 10
VPC 2 Side A IP 10.0.0.2/28 Side B IP : 10.0.0.3/28 Secondary IP : 10.0.0.1/28 vl 10
Is this setup supported by ACI?
Thanks.
3 REPLIES 3
RedNectar
Engager
@ChrisMac70330 ,
If you doing
Static Routing to a FW with SVI
as you say you are, then you only need one VPC and your configuration design:
..is perfectly correct
If you are connecting to two firewalls, it is a different story...
I hope this helps
Don't forget to mark answers as correct if it solves your problem. This helps others find the correct answer if they search for the same problem
RedNectar
aka Chris Welsh
Yes, I am connecting two FW.
Does this help?
https://unofficialaciguide.com/2017/08/03/l3out-connecting-to-activestandby-fw/
Not using VPCs though - still uses the SVI concept
RedNectar
aka Chris Welsh
Content for Community-Ad
