07-15-2021 02:44 AM - edited 07-15-2021 02:50 AM
We are trying to install the ACI plugin on vcenter 6.7 (for AVE) using a centos 7 VM but after deploying it In vcenter, it shows up that the plugin is incompatible.
this error is shown: "The plug-in only supports the vSphere Web Client (Flash)."
We are using the latest version of the plugin (5.2.2).
Is there any solution?
Thnx
Solved! Go to Solution.
07-15-2021 05:31 AM
You're likely using the wrong plugin. You need the HTML plugin:.
https://software.cisco.com/download/home/285968390/type/286326595/release/1.0.4
Robert
07-15-2021 05:31 AM
Robert
