Beginner
ACI - Search Categories - Issue
In the 2.1(1h) release , it seems the small arrow used to display the "Search Categories" doesn't work anymore (see attached).
Could you confirm that you have the same behavior and it should be solved in the next release ?
Thank you
Ju
Everyone's tags (1)
1 ACCEPTED SOLUTION
Highlighted
Agree this does NOT function
Agree this does NOT function the way it should.  Will open an enhancement request to have this corrected.
Robert
4 REPLIES 4
Hi Ju,
Hi Ju,
It works as expected in 2.1(1h). You cannot click the arrow directly. You need to type in some text for the search bar to display options. Once you get some options in the dropdown you can select one from them. See the attached screenshot.
Hope this helps.
Naveen
Thanks & Regards Venkata Naveen Chapa
Highlighted
Robert
Beginner
Thank you Robert. Ju
Thank you Robert.
Ju
Tracking as CSCvc23976.  If
Tracking as CSCvc23976.  If possible, please open a quick TAC case and simply request to have your SR linked to this defect referenced above along with the other defect you mentioned today.  This will help increase the priority to get this resolved quicker.
Robert
Content for Community-Ad
August's Community Spotlight Awards
