ACI Simulator 4.2(4i) - How do I extend storage?
digvisin
Hi all,
I recently deployed ACI Simulator version 4.2(4i), and it works great. However, by default the OVA deployed is set to use 100GB only. In ESXi, I've assigned 500GB but its not showing up in the apic. Any help on this would be extremely helpful.
Francesco Molino
I’m quite sure you can’t do that as the VM is here to help testing how ACI works, try integration with 3rd parties and play around with APIs.
Cisco already increased the hardware resources from previous 3.x ova.
For my personal information, why would you require 500GB of disk on the simulator?
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
