ACI simulator not accessible on UI
goranje
We have installed AVI simulator VM .ova file on our environment
We followed the instruction and leave all default settings, after that the ACI is accessible via console with admin user and pass.
But we can not access the UI on https.
The login page is not even displayed. It seems that the simulator is not listening on https port.
Do any one have this issues?
Any idea what to check/do next?
Best regards,
We solved the problem, the issue was that colleagues assumed that the port-group was by default in promiscuous mode, but it was not.
We put also the port-group in promiscuous mode and it was ok.
5 Replies 5
Francesco Molino
When doing the initial setup, it asks you for an ip address on vlan 4 (infrastructure vlan). Did you attach the correct vmware port-group for vlan 4 on your 1st nic?
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Hi @goranje,
Thank you very much for posting the details of the fix.  This is always very helpful!
Claudia
You're welcome
Francesco
AminRamadan
In case , if anyone wondering how to change the Promiscuous mode from Exsi, please see the pic.
