ACI Upgrade and fan incompatibility
brian.holmes
I ran through this tool to check hardware compatibility support
https://www.cisco.com/c/dam/en/us/td/docs/Website/datacenter/acihwsupport/index.html
it says the following FANs are not compatible with ACI 14.2(6)
  • NXA-FAN-30CFM-B
  • NXA-FAN-30CFM-F
we just installed two new switches which has these FANs...is 14.2(6) really not compatible with the latest FAN hardware?
Brian Holmes
Verizon
Sergiu.Daniluk
HI @brian.holmes
They are compatible: https://www.cisco.com/c/en/us/td/docs/dcn/aci/apic/4x/release-notes/cisco-aci-nx-os-release-notes-1426.html#NewHardwareFeatures
For hw compatibility always check the release notes of the specific version you need.
Cheers,
Sergiu
Sergiu.Daniluk
HI @brian.holmes
Cheers,
Sergiu
