05-04-2017 12:37 PM - edited 03-01-2019 05:13 AM
Hi Team ,
we have some issues when we tried to integrate VMM.
when we push the DVS into vcenter , all looks fine . and we add one ESX host into that DVS. but for some reason , it keep to use lldp (even my interface-polict disabled the lldp and enable the cdp only )
every time I have to ask server guy to change to CDP in ESXi side
not sure why
thanks
Daniel
Solved! Go to Solution.
05-04-2017 01:06 PM
Also try to make the change in Firefox. Here's the bug I'm suspecting: CSCvc84697.
Robert
05-04-2017 01:37 PM
Tried with Firefox, unable to update the vSwitch policies after creating the VMM domain
05-04-2017 12:43 PM
Should never have to touch CDP on the host side. All policies push from APIC, if not you have a problem.
Did you configured a vSwitch policy under the VMM domain to Disable LLDP and Enable CDP? LLDP defaults to enable, CDP defaults to disabled, so you need specific policies for both defined under the VMM domain.
You might very well have an Interface Policy, but if you want the settings to push to ESX, you need the vSwitch policy.
Robert
05-04-2017 12:59 PM
Thanks for such a quick reply.
we tried to modify like that , but the submit button is grey , cannot change that .
05-04-2017 01:00 PM
There was a known bug with that. Which version are you running on APIC?
05-04-2017 01:03 PM
version is 2.1(1i)
05-04-2017 01:06 PM
Robert
05-04-2017 01:37 PM
05-04-2017 03:59 PM
You can use the API to change the settings also. See if that works.
Use postman or similar to push the config change. This will tell you if its a UI issue or otherwise.
Robert
05-05-2017 05:31 AM
thanks a lot Robert !! will try that !
05-05-2017 09:40 AM
Ya ,, it works !
thanks a lot !
05-05-2017 10:22 AM
Great to hear :)
05-04-2017 01:01 PM
05-04-2017 01:12 PM
another thing need to mention , we only deployed DVS , not AVS
1. our understanding is when interface-policy defined lldp disable and cdp enable , when deploy the DVS , all policy should stay the same
2. in the wizard of the VMM domain , the Vswitch policy part is only of AVS ? or it is for DVS as well ?
Thanks !
05-04-2017 01:28 PM
Applies to both.
Robert
