01-26-2021 04:56 AM
In ACI, can we run vPC using two different model - e.g, N9K-C93108TC-EX and N9K-C93108TC-FX.
I saw in documentation that this is not possible in NXOS, not sure about ACI.
Thanks !
Eng We
Solved! Go to Solution.
01-26-2021 05:23 AM - edited 01-26-2021 05:39 AM
You can't mix Gen1(-E) & Gen2+(-EX, -FX*) switches in a VPC pair. Officially, we support EX & FX in the same VPC pair, but personally I would caution against this and try at all times to keep VPC members as the same Generation (EX & EX, FX & FX) - primarily due to certain features requiring particular generation of switch (Ex. MacSec, Telemetry etc).
Under "Virtual Port Channels" Section.
Robert
01-26-2021 05:15 AM
You can mix the models high level.
Robert
