Highlighted
Participant
APIC 2 not responding !
I tried to upgrade APICs to ve 3.1.2o but one of my APIC (#2) is not responding to reload.
I have tried reloading 3.1.1i from GUI, CLI manullay but no response.
APIC 1 & 3 responding well. It seems configs are not applying on the #2. However controller status is fully fit.
//Umair
1 ACCEPTED SOLUTION
Highlighted
Re: APIC 2 not responding !
Suggest trying to clean reload the APIC:
1. Decomission the APIC2 from the UI - give it 10mins to complete.
2. From APIC2 CLI:
   acidiag touch clean
   acidiag reload
3.  Once its boots back up, recommission APIC2 fro the UI.  Allow 10mins to complete.
This should clean up the APIC's stale NTP config.  If this doesn't work, you can try to re-setup the APIC using:
2. From APIC2 CLI:
    acidiag touch clean
    acidiag touch setup
    acidiag touch reload
After this you'll need to re-assign the appropriate details via KVM console (IP, Hostname, etc).  The rest of the policies should be pushed once it joins the cluster.  Give it some time to go fully fit and it "should" upgrade itself to the Cluster's FW level.
Robert
12 REPLIES 12
Highlighted
A few things to look at:
1. Get the output of 'acidiag avread' from APIC1
2. What does the KVM console for APIC2 show?
Robert
Highlighted
Participant
apic1# acidiag avread
Local appliance ID=1 ADDRESS=10.0.0.1 TEP ADDRESS=10.0.0.0/16 CHASSIS_ID=31d1ff42-0630-11e7-aa84-058c938afcc4
Cluster of 3 lm(t):1(2018-05-16T12:35:29.607+02:00) appliances (out of targeted 3 lm(t):2(2018-05-17T13:52:11.471+02:00)) with FABRIC_DOMAIN name=ACI-LAB set to version=apic-3.1(2o) lm(t):1(2018-05-17T14:16:22.453+02:00); discoveryMode=PERMISSIVE lm(t):0(1970-01-01T02:00:00.003+02:00)
        appliance id=1  address=10.0.0.1 lm(t):1(2018-05-16T13:03:39.793+02:00) tep address=10.0.0.0/16 lm(t):1(2018-05-16T13:03:39.793+02:00) oob address=172.19.1.20/24 lm(t):1(2018-05-16T12:35:30.048+02:00) version=3.1(2o) lm(t):1(2018-05-17T13:52:13.088+02:00) chassisId=31d1ff42-0630-11e7-aa84-058c938afcc4 lm(t):1(2018-05-17T13:52:13.088+02:00) capabilities=0X7FFFFFFFF--0X2020--0X7 lm(t):1(2018-05-17T14:20:30.246+02:00) rK=(stable,present,0X206173722D687373) lm(t):1(2018-05-16T12:35:30.053+02:00) aK=(stable,present,0X206173722D687373) lm(t):1(2018-05-16T12:35:30.053+02:00) cntrlSbst=(APPROVED, xx) lm(t):1(2018-05-17T13:52:13.088+02:00) (targetMbSn= lm(t):0(zeroTime), failoverStatus=0 lm(t):0(zeroTime)) podId=1 lm(t):1(2018-05-16T13:03:39.793+02:00) commissioned=YES lm(t):1(zeroTime) registered=YES lm(t):1(2018-05-16T13:03:39.793+02:00) standby=NO lm(t):1(2018-05-16T13:03:39.793+02:00) active=YES(2018-05-16T13:03:39.793+02:00) health=(applnc:255 lm(t):1(2018-05-17T13:52:15.087+02:00) svc's)
        appliance id=2  address=10.0.0.2 lm(t):3(2018-05-16T14:48:31.356+02:00) tep address=10.0.0.0/16 lm(t):2(2017-03-16T00:55:31.097+02:00) oob address=172.19.1.21/24 lm(t):1(2018-05-17T13:52:13.528+02:00) version=3.1(1i) lm(t):2(2018-05-17T13:52:13.189+02:00) chassisId=71fb2242-09d2-11e7-a7b7-abc87eae134c lm(t):2(2018-05-17T13:52:13.189+02:00) capabilities=0X7FFFFFFFF--0X2020--0 lm(t):2(2018-03-19T07:08:24.116+02:00) rK=(stable,present,0X206173722D687373) lm(t):1(2018-05-17T13:52:13.528+02:00) aK=(stable,present,0X206173722D687373) lm(t):1(2018-05-17T13:52:13.528+02:00) cntrlSbst=(APPROVED, xx) lm(t):0(zeroTime) (targetMbSn= lm(t):0(zeroTime), failoverStatus=0 lm(t):0(zeroTime)) podId=1 lm(t):2(2018-03-19T07:36:36.353+02:00) commissioned=YES lm(t):1(2018-05-16T12:35:29.606+02:00) registered=YES lm(t):3(2017-03-20T15:10:05.325+02:00) standby=NO lm(t):3(2018-05-16T12:35:29.606+02:00) active=YES(2018-05-17T13:52:12.951+02:00) health=(applnc:255 lm(t):2(2018-05-17T13:52:59.507+02:00) svc's)
        appliance id=3  address=10.0.0.3 lm(t):3(2018-05-16T14:48:24.642+02:00) tep address=10.0.0.0/16 lm(t):3(2017-03-20T15:09:59.852+02:00) oob address=172.19.1.22/24 lm(t):1(2018-05-17T13:52:13.484+02:00) version=3.1(2o) lm(t):3(2018-05-17T13:52:13.164+02:00) chassisId=6aa68208-0d6e-11e7-8534-abe884595d92 lm(t):3(2018-05-17T13:52:13.164+02:00) capabilities=0X7FFFFFFFF--0X2020--0 lm(t):3(2018-05-17T14:20:44.059+02:00) rK=(stable,present,0X206173722D687373) lm(t):1(2018-05-17T13:52:13.484+02:00) aK=(stable,present,0X206173722D687373) lm(t):1(2018-05-17T13:52:13.484+02:00) cntrlSbst=(APPROVED, xx) lm(t):0(zeroTime) (targetMbSn= lm(t):0(zeroTime), failoverStatus=0 lm(t):0(zeroTime)) podId=1 lm(t):3(2018-05-16T14:48:24.642+02:00) commissioned=YES lm(t):1(2018-05-16T12:35:29.606+02:00) registered=YES lm(t):1(2017-03-20T15:10:11.335+02:00) standby=NO lm(t):3(2018-05-16T14:48:24.642+02:00) active=YES(2018-05-16T14:20:16.190+02:00) health=(applnc:255 lm(t):3(2018-05-17T13:52:14.912+02:00) svc's)
clusterTime=<diff=-1696893 common=2018-05-22T16:25:15.383+02:00 local=2018-05-22T16:53:32.276+02:00 pF=<displForm=0 offsSt=0 offsVlu=7200 lm(t):2(2018-05-17T13:52:11.446+02:00)>>
Fault on the APIC 2 . But I did remove the NTP setting from GUI From 172.19.0.10 but it seems it does not propagate to APIC 2.
Properties
F1574
critical
2018-03-19T07:39:04.495+02:00
Raised
topology/pod-1/node-2/sys/ntpq-172.19.0.10
Ntp configuration on Node 2 for 172.19.0.10 is not reachable
Highlighted
Participant
This is from APIC 2
apic2# acidiag avread Local appliance ID=2 ADDRESS=10.0.0.2 TEP ADDRESS=10.0.0.0/16 CHASSIS_ID=71fb2242-09d2-11e7-a7b7-abc87eae134c Cluster of 3 lm(t):2(2018-03-19T07:08:23.679+02:00) appliances (out of targeted 3 lm(t):2(2018-05-17T13:52:11.471+02:00)) with FABRIC_DOMAIN name=ACI-LAB set to version=apic-3.1(2o) lm(t):1(2018-05-17T14:16:22.453+02:00); discoveryMode=PERMISSIVE lm(t):0(1970-01-01T02:00:00.003+02:00) appliance id=1 address=10.0.0.1 lm(t):3(2018-05-16T14:48:31.356+02:00) tep address=10.0.0.0/16 lm(t):1(2017-03-16T00:55:37.049+02:00) oob address=172.19.1.20/24 lm(t):2(2018-05-17T13:52:13.521+02:00) version=3.1(2o) lm(t):1(2018-05-17T13:52:13.088+02:00) chassisId=31d1ff42-0630-11e7-aa84-058c938afcc4 lm(t):1(2018-05-17T13:52:13.088+02:00) capabilities=0X7FFFFFFFF--0X2020--0 lm(t):1(2018-05-17T14:20:30.246+02:00) rK=(stable,present,0X206173722D687373) lm(t):2(2018-05-17T13:52:13.521+02:00) aK=(stable,present,0X206173722D687373) lm(t):2(2018-05-17T13:52:13.521+02:00) cntrlSbst=(APPROVED, xx) lm(t):0(zeroTime) (targetMbSn= lm(t):0(zeroTime), failoverStatus=0 lm(t):0(zeroTime)) podId=1 lm(t):1(2018-05-16T13:03:39.793+02:00) commissioned=YES lm(t):2(2017-03-20T15:10:05.325+02:00) registered=YES lm(t):3(2017-03-20T15:10:05.325+02:00) standby=NO lm(t):1(2018-05-16T13:03:39.793+02:00) active=YES(2018-05-17T13:52:13.092+02:00) health=(applnc:255 lm(t):1(2018-05-17T13:52:15.087+02:00) svc's) appliance id=2 address=10.0.0.2 lm(t):2(2018-03-19T07:36:36.353+02:00) tep address=10.0.0.0/16 lm(t):2(2018-03-19T07:36:36.353+02:00) oob address=172.19.1.21/24 lm(t):2(2018-05-17T13:52:11.258+02:00) version=3.1(1i) lm(t):2(2018-05-17T13:52:13.189+02:00) chassisId=71fb2242-09d2-11e7-a7b7-abc87eae134c lm(t):2(2018-05-17T13:52:13.189+02:00) capabilities=0X7FFFFFFFF--0X2020--0X7 lm(t):2(2018-03-19T07:08:24.116+02:00) rK=(stable,present,0X206173722D687373) lm(t):2(2018-05-17T13:52:11.268+02:00) aK=(stable,present,0X206173722D687373) lm(t):2(2018-05-17T13:52:11.268+02:00) cntrlSbst=(APPROVED, xx) lm(t):2(2018-05-17T13:52:13.189+02:00) (targetMbSn= lm(t):0(zeroTime), failoverStatus=0 lm(t):0(zeroTime)) podId=1 lm(t):2(2018-03-19T07:36:36.353+02:00) commissioned=YES lm(t):2(zeroTime) registered=YES lm(t):2(2018-03-19T07:36:36.353+02:00) standby=NO lm(t):2(2018-03-19T07:36:36.353+02:00) active=YES(2018-03-19T07:36:36.353+02:00) health=(applnc:255 lm(t):2(2018-05-17T13:52:59.507+02:00) svc's) appliance id=3 address=10.0.0.3 lm(t):3(2018-05-16T14:48:24.642+02:00) tep address=10.0.0.0/16 lm(t):3(2017-03-20T15:09:59.852+02:00) oob address=172.19.1.22/24 lm(t):2(2018-05-17T13:52:13.521+02:00) version=3.1(2o) lm(t):3(2018-05-17T13:52:13.164+02:00) chassisId=6aa68208-0d6e-11e7-8534-abe884595d92 lm(t):3(2018-05-17T13:52:13.164+02:00) capabilities=0X7FFFFFFFF--0X2020--0 lm(t):3(2018-05-17T14:20:44.059+02:00) rK=(stable,present,0X206173722D687373) lm(t):2(2018-05-17T13:52:13.521+02:00) aK=(stable,present,0X206173722D687373) lm(t):2(2018-05-17T13:52:13.521+02:00) cntrlSbst=(APPROVED, xx) lm(t):0(zeroTime) (targetMbSn= lm(t):0(zeroTime), failoverStatus=0 lm(t):0(zeroTime)) podId=1 lm(t):3(2018-05-16T14:48:24.642+02:00) commissioned=YES lm(t):1(2018-05-16T12:35:29.606+02:00) registered=YES lm(t):1(2017-03-20T15:10:11.335+02:00) standby=NO lm(t):3(2018-05-16T14:48:24.642+02:00) active=YES(2018-05-17T13:52:13.163+02:00) health=(applnc:255 lm(t):3(2018-05-17T13:52:14.912+02:00) svc's) --------------------------------------------- clusterTime=<diff=-1696892 common=2018-05-22T16:34:20.092+02:00 local=2018-05-22T17:02:36.984+02:00 pF=<displForm=0 offsSt=0 offsVlu=7200 lm(t):2(2018-05-17T13:52:11.446+02:00)>>
Highlighted
2. From APIC2 CLI:
   acidiag touch clean
   acidiag reload
2. From APIC2 CLI:
    acidiag touch clean
    acidiag touch setup
Robert
Highlighted
Participant
just a side question... is there any way to get the CIMC address from GUI or configuration of APIC ?
Highlighted
No. IMC is completely out of band for the platform. Has no interaction with the Host APIC OS. Either you know the IMC IP, or you can reboot it with a monitor/keyboard locally connected and watch the console. The IMC details will be shown on screen during the POST process.
Robert
Highlighted
Participant
ok it was  :)
 acidiag reboot
Highlighted
Yes.  Sorry typo.  'acidiag reboot'.
Highlighted
Participant
I did as you stated... Now come another hassle.
as APCI 1 & 3 are ver 3.1.2o and APIC 2 is 3.1.1i.
APIC 2 heath is 'Data Layer Partially diverge'
F1824
critical
2018-05-22T17:54:35.607+02:00
Raised
topology/pod-1/node-1/lon/incmptblClsPeer-version_incompatible_with_cluster-2-3.1(1i)-apic-3.1(2o)
Peer controller is incompatible: Version incompatible with cluster. The controller ID is 2, its version is 3.1(1i). Cluster Version is apic-3.1(2o)
Highlighted
Let's run the upgrade manually against APIC2.  If you have the APIC ISO for 3.1(2o) you can mount it to the IMC vMedia, and boot the APIC.  This will auto-upgrade APIC2.  After it completes, you should be able to reboot it and into the cluster successfully.
Robert
Highlighted
Participant
Hi Robert,
I just finish downgrading the other two APICs 1 & 3 to 3.1.1i.
Now it seems they are all fully fit.
However your second option is worth a try. As downgrading other two APICs is a bit risky ?
Thanks for your kind help !
// Umair
Highlighted
Are you going to re-attempt the upgrade?  Ensure the NTP policy across all APICs is consistent before doing so.
Robert
