APIC Controller not discovering LEAF's or Spines
Sean Pillay
Hi Guys
Our company just purchased some ACI Kit recently
However the APIC is not discovery the leaf or spine, if I do a show lldp neighbor on the leaf it can see the APIC
I have disabled LLDP for the VIC
Perfromed the following on the APIC
acidiag touch clean
acidiag setup
acidiag reload
I also reset the leaf with no luck, what I am doing wrong ?
Any help is much appreciated
With the  C93180YC-EX, you will need 11.3(1) or later and the APIC will need to be 1.3(1) and later.
Cisco Application Policy Infrastructure Controller, Release 1.3(1), Release Notes
  • http://www.cisco.com/c/en/us/td/docs/switches/datacenter/aci/apic/sw/1-x/release/notes/apic_rn_131.html
Cisco NX-OS Release 11.3(1) Release Notes for Cisco Nexus 9000 Series ACI-Mode Switches
  • http://www.cisco.com/c/en/us/td/docs/switches/datacenter/aci/apic/sw/1-x/release/notes/aci_nxos_rn_1131.html
So as you mentioned, you will need to upgrade your APIC to a supported release and then upgrade all the switches to the matching release.
T.
11 Replies 11
Sean Pillay
Okay update i managed to get the APIC to see the leaf at least by setting the NIC setting in the CIMC interface from shared LOM to dedicated however now my APIC sees the leaf but when I give it a node ID and node name the leaf does not get an IP address
Just FYI time on leaf and controller is off by a minute
Any ideas ?
Update 2: Found this
LAB1# acidiag fnvread
ID Name Serial Number IP Address Role State LastUpdMsgId
110 LF-110 FDOxxxxxxx 0.0.0.0 leaf unsupported 0
Total 1 nodes
time offset by couple of minute is not going to affect Fabric discovery.
can you confirm if both APIC and leaf here are running the same software version.
Seems like the leaf has firmware that is way ahead of the APIC, going to upgrade the APIC in 10 minutes
What version is your APIC?
What Model Numbers are you Leaf and Spine nodes?
T.
Tomas, based on serial number of Leaf, it is a 93180YC-EX.
Apic 1.2(1i)
Spine C9336PQ
Leaf C93180YC-EX
T.
You are 100%. In my case the leaf shipped with firmware for APIC version 2.1 so I just upgrade to 2.1 and now my APIC has discovered my leaf and spines. I will add the other APICS, Spines and leaves next week
Friendly reminder, not a great idea to post your device's IPs and/or Serial Numbers on public forums.  I've blanked them out above (SN).
Thanks!
Robert
(Moderator)
Thanks much appreciated
