05-09-2019 07:47 AM - edited 05-09-2019 07:49 AM
Hi All,
I just finished the initial setup for new ACI.
Config the new OOB-Magement IP address for 3 APICs
But when open the "Node Management Addresses", the IP Address for APIC isn't there.
However, when I open the APIC 1-3 configuration under the System>Controller, each APIC has its OOB-Management IP and I can access the IP.
Is this normal?
05-09-2019 10:16 AM
This is normal, You have to add policies for Nodes 1, 2, and 3 manually to the mgmt tenant. You can also change the addresses by adding a policy with a different IP address.
05-09-2019 11:55 AM
Hi stcorry,
Thanks for the answer.
But i have another questions, when i open Out-of-Band EPG - default under "Node Management EPGs"
Configuration Issues: Not Associated With
Management Zone
Configuration State: failed-to-apply
and the faults logg
Fault F0523: "Configuration failed for EPG default due to Not Associated With Management Zone" is raised.
What does all that means?
05-09-2019 01:50 PM
Hi @stcorry ,
This (Fault 0523) is a bug thta has been around forever, (https://bst.cloudapps.cisco.com/bugsearch/bug/CSCut58022/?rfs=iqvred) proported to be fixed in version 3 (https://bst.cloudapps.cisco.com/bugsearch/bug/CSCuz59329/?rfs=iqvred) but it would seem is still hanging around.
Don't loose sleep over it.
I hope this helps
Don't forget to mark answers as correct if it solves your problem. This helps others find the correct answer if they search for the same problem
05-09-2019 05:42 PM - edited 05-09-2019 05:44 PM
Hi Chris,
By the way, the software we use is version 2.0(1n)
What I understand from your answer is, to solve the Fault 0523 problem is to upgrade the ACI software to version 3.x? right?
In "Out-of-Band EPG"
Configuration Issues: Not Associated With Management Zone
What does it mean?
05-09-2019 06:22 PM
According to the Bug report it should go away in v3.0: I don't have a system at my disposal at the moment, but I believe it has gone away with later version (i.e. 3.x)
05-10-2019 07:12 AM
