10-29-2020 05:32 AM
Hi all,
can we modify the TLV values of LLDP Packets ?
we try to implement our ACI / Leaves with Nutanix
connection runs over *snmp* and *lldp*
Version ACI Fabric 4.2(4i)
Leafs / Spines: 14.2(4i)
LLDP TLV
TLV: PortID
Value: local Eth1/5
example output:
LLDP neighbors:
Interface: eth5, via: LLDP, RID: 3,
TTL: 120
MgmtIP:
Capability: Bridge, on
Capability: Router, on
Port:
PortID: local Eth1/5
VLAN: 345, pvid: yes
LLDP-MED:
Device Type: Network Connectivity Device
Capability: Capabilities, yes
Capability: Policy, yes
Capability: MDI/PSE, yes
Unknown TLVs:
TLV: OUI: 00,01,42, SubType: 1, Len: 1 01
TLV: OUI: 00,01,42, SubType: 216, Len: 2 00,00
TLV: OUI: 00,01,42, SubType: 201, Len: 1 01
TLV: OUI: 00,01,42, SubType: 212, Len: 11 46,44,4F,32,33,34,35,30,36,45,44
TLV: OUI: 00,01,42, SubType: 214, Len: 15 4E,39,4B,2D,43,39,33,31,38,30,59,43,2D,46,58
TLV: OUI: 00,01,42, SubType: 210, Len: 14 6E,39,30,30,30,2D,31,34,2E,32,28,34,69,29
TLV: OUI: 00,01,42, SubType: 202, Len: 1 01
TLV: OUI: 00,01,42, SubType: 211, Len: 2 0F,7F
TLV: OUI: 00,01,42, SubType: 215, Len: 8 4F,4C,48,45,39,32,32,37
TLV: OUI: 00,01,42, SubType: 206, Len: 12 64,63,2D,62,69,74,73,2D,6F,6C,2D,31
TLV: OUI: 00,01,42, SubType: 208, Len: 4 0A,70,98,42
TLV: OUI: 00,01,42, SubType: 203, Len: 4 00,00,00,E3
TLV: OUI: 00,01,42, SubType: 205, Len: 2 00,02
TLV: OUI: 00,01,42, SubType: 207, Len: 164 01,0A,6F,00,01,34,35,38,39,39,38,32,36,2D,35,61,30,39,2D,31,31,65,61,2D,39,37,34,33,2D,65,62,63,31,37,33,34,62,66,61,63,34,04,0A,6F,00,04,63,66,33,61,33,35,66,63,2D,35,61,30,66,2D,31,31,65,61,2D,62,39,35,33,2D,63,33,31,36,65,64,62,36,61,39,31,65,02,0A,6F,00,02,31,61,38,36,30,32,61,38,2D,35,61,30,66,2D,31,31,65,61,2D,61,34,66,39,2D,63,62,35,65,66,36,32,64,38,66,61,63,03,0A,6F,00,03,38,35,61,38,61,65,32,38,2D,35,61,30,66,2D,31,31,65,61,2D,62,32,63,65,2D,62,66,33,37,30,33,37,36,36,61,35,31
Solved! Go to Solution.
10-29-2020 08:14 AM
10-29-2020 06:23 AM
Hi buddy,
May be this link will help you on the integration part of Nutanix with Cisco ACI
https://www.nutanix.com/go/cisco-aci-with-nutanix
Inderdeep Singh
10-30-2020 01:46 AM
thanks for info !
10-29-2020 08:14 AM
Not currently possible to modify TLVs on LLDP within ACI.
Robert
