04-11-2020 10:00 AM
Dear Community,
Using Ansible aci_rest module, I would like to create a playbook to assign EPG static port-mapping, but I cannot get it working.
Anyone who might have done it before and can share their script I would highly appreciate it.
Kind Regards,
Tlatlaru
Solved! Go to Solution.
04-11-2020 11:03 AM - edited 04-11-2020 11:12 AM
Below is an example using aci_rest:
Note: make sure that the tenant>app>epg exists before running this playbook.
--- - name: Static Bind Using aci_rest hosts: apic connection: local gather_facts: False tasks: - name: Add static path aci_rest: host: "{{ inventory_hostname }}" username: "{{ username }}" password: "{{ password }}" validate_certs: False method: "post" path: "api/mo/tn-{{ item.tenant }}/ap-{{ item.app }}/epg-{{ item.epg }}.json" content: '{"fvRsPathAtt":{"attributes":{"annotation":"","descr":"","dn":"uni/tn-{{ item.tenant }}/ap-{{ item.app }}/epg-{{ item.epg }}/rspathAtt-[topology/pod-{{ item.pod }}/paths-{{ item.leaf }}/pathep-[eth1/{{ item.port }}]]","encap":"vlan-{{ item.vlan}","instrImedcy":"immediate","mode":"regular","primaryEncap":"unknown","tDn":"topology/pod-{{ item.pod }}/paths-{{ item.leaf }}/pathep-[eth1/{{ item.port }}]" }}}' with_items: - tenant: "Production" app: "AppCenter" epg: "Web" pod: "1" leaf: "101" port: "24" vlan: "2400" - tenant: "Production" app: "AppCenter" epg: "Web" pod: "1" leaf: "102" port: "22" vlan: "2400"
Alternatively, you can use aci_role: https://github.com/datacenter/ansible-role-aci-model
Sergiu
Sergiu
04-12-2020 01:21 PM
Hi Sergiu,
Thanks for your help, following your tip to do more.
09-19-2020 05:49 AM
Hello, thank you for posting this it is extremely helpful. I see your note there that says make sure that the endpoint group exist before you try to make these changes via the Ansible playbook. I was wondering if there was a way to check whether or not the endpoint group already existed via an easy method inside of Ansible?
09-20-2020 05:20 AM
Hi @Rob R.
Yes, you can use the "aci_epg" module: https://docs.ansible.com/ansible/latest/modules/aci_epg_module.html
- name: Add a new EPG aci_epg: host: apic username: admin password: SomeSecretPassword tenant: production ap: intranet epg: web_epg description: Web Intranet EPG bd: prod_bd preferred_group: no state: present delegate_to: localhost
- name: Query an EPG aci_epg: host: apic username: admin password: SomeSecretPassword tenant: production ap: ticketing epg: web_epg state: query delegate_to: localhost register: query_result
You can play with the state attribute to either create or query:
Stay safe,
Sergiu
04-11-2020 01:42 PM - edited 04-11-2020 01:43 PM
Hello again,
I would like to share with you how to create any ansible playbook, using aci_rest.
Rules are simple:
1. You need to have a working example of the desired object. Or at least have it configured. I will use the static binding, but same workflow will apply for any other object.
2. Save the configuration of the object. You can do that using right click on the object > Save as... ; A pop-up will appear. Download only the self-object configuration, in json.
3. The configuration will look like this:
{ "totalCount": "1", "imdata": [ { "fvRsPathAtt": { "attributes": { "annotation": "", "descr": "", "dn": "uni/tn-ANS/ap-App1/epg-EPG1/rspathAtt-[topology/pod-1/paths-101/pathep-[eth1/5]]", "encap": "vlan-3678", "instrImedcy": "immediate", "mode": "regular", "primaryEncap": "unknown", "tDn": "topology/pod-1/paths-101/pathep-[eth1/5]" } } } ] }
There are a couple of things which are important in the config:
4. Find the variables in the path & config (tenant, epg, vlan, interface etc) and change them with {{ item.variable }}. because you will use the with_items for looping. After the change, the config looks like this:
Object DN:
Config:
{ "fvRsPathAtt": { "attributes": { "annotation": "", "descr": "", "dn": "uni/tn-{{ item.tenant }}/ap-{{ item.app }}/epg-{{ item.epg }}/rspathAtt-[topology/pod-{{ item.pod }}/paths-{{ item.leaf }}/pathep-[eth1/{{ item.port }}]]", "encap": "vlan-{{ item.vlan}", "instrImedcy": "immediate", "mode": "regular", "primaryEncap": "unknown", "tDn": "topology/pod-{{ item.pod }}/paths-{{ item.leaf }}/pathep-[eth1/{{ item.port }}]" } } }
5. Put all pieces together (see playbook code in my first post).
Hope it helps,
Sergiu
10-18-2022 06:40 AM
need to add multiple ports to epg with ansible
below playbook is not working
Task
- name: Deploy Static Path binding for given EPG
aci_static_binding_to_epg:
host: apic
tenant: "{{ tenant }}"
hostname: "{{ inventory_hostname }}"
username: "{{ user }}"
password: "{{ pass }}"
ap: "POD01_APP"
epg: "database"
encap_id: 623
deploy_immediacy: lazy
interface_mode: regular
interface_type: switch_port
pod_id: 1
leafs: "{{leaf}}"
interface: "{{portlist}}"
state: present
validate_certs: false
Var
tenant: aciproglab01
vrf1: POD01_vrf_1
vrf2: POD01_vrf_2
app_profile_name: POD01_APP
leaf: 101
portlist:
- interface: "1/3"
- interface: "1/5"
