01-27-2021 04:54 AM
Hi all,
I know that our APICs use out-of-band interface for external connections. But I want to check whether our controllers reach a website from internet. Unfortunately there is no telnet commands in APIC and leaf switches even in bash. How can I verify connectivity ?
Thank you
Solved! Go to Solution.
01-27-2021 05:19 AM
HI @OBD
curl might be the best and easy way to verify connectivity with a website:
admin@apic1:~> curl -Is http://www.google.com | head -n 1 HTTP/1.1 200 OK
Cheers,
Sergiu
01-27-2021 05:19 AM
HI @OBD
Cheers,
Sergiu
01-27-2021 05:48 AM
Thank you for your reply. It has worked for me
