Cisco APIC AAA TACACS+ Management via CLI?
fc00::/7
In APIC, the implementation of AAA can be seen in the following path:
APIC > ADMIN > AAA > RADIUS Management > RADIUS Providers
APIC > ADMIN > AAA > TACACS+ Management > TACACS+ Providers
*Image from https://www.cisco.com/c/en/us/td/docs/switches/datacenter/aci/apic/sw/1-x/basic-config/b_ACI_Config_Guide/b_ACI_Config_Guide_chapter_011.html
What is the equivalent command for this? I need to get this info including `Host Name`, `Description`, `Port` number and `Timeout (sec)` setting via SSH.
APIC# show aaa ?
authentication Show AAA Authentication information
groups Show AAA group information
APIC#
APIC# show aaa authentication ?
<CR>
Default : radius
Console : radius
APIC# show aaa groups ?
<CR>
APIC#
Total number of Groups: 2
RadiusGroups : XYZ-RADIUS
TacacsGroups : XYZ-TACACS
LdapGroups :
Sergiu.Daniluk
Hello again :-)
You can see the details in:
apic# show running-config tacacs-server
apic# show running-config radius-server
Generally speaking, you can see all configuration using:
Sergiu
Sergiu.Daniluk
Hello again :-)
Sergiu
