1303
michael.leonard1
Beginner
Citrix Netscaler POC KIT for ACI
If you are using NetScaler with Cisco ACI and you'd like to automate configurations from scripts we have this POC Kit to help you get started. There are Readme files and also documentation notes in the script headers to help you get going. The NetScaler Device package for ACI is required to be loaded in the Cisco APIC. You can download these scripts, edit them as you wish to fit them your environment, then push them using the Python script that is included.
To get to the repository on Github use this link: NetScaler ACI POC Kit on Github
0 REPLIES 0
