11-02-2021 05:48 AM
Unable to login to the APIC controller from SSH. We got the error below.
XXXXXX:~$ ssh -l ACxxx 192.x.x.x.
Application Policy Infrastructure Controller
acxx@192.x.x.x's password:
[Errno -3] Temporary failure in name resolution.
^C^C
^C^C
11-05-2021 01:39 AM
Hello @Jothiprakash.S5886 ,
I have seen this in the past.
An APIC reload solves the problem. If you do not want to reload the APIC you might need to call TAC and ask them to restart the ssh daemon via root user.
Hope that helps,
ADP
11-05-2021 02:15 AM
Thanks for your revert. Is there any documents for this
11-05-2021 04:27 AM
AFAIK there is not a document describing such behaviour and related solution.
If you would like a deeper analysis and a supported resolution/workaround I suggest you to open a TAC case.
ADP
