Commands to verify if LED status of port is working correctly or not.
 have nexus switch used in ACI fabric and i want to know commands through which i can verify if LED status of port is working correctly or not cause i have two ports in vpc which ware continuosly flashing from greeen to amber..config looks good ..failover working fine..after removing gbic from port still showing same behavior ..this has caused me to think that there is some issue with the LED indication itself..Please help
Sergiu.Daniluk
There is no command for verifying if a LED is functioning correctly, however what you describe there sounds like you have the beacon turned on for your interface. Go to Fabric -> Inventory -> Pod x -> Leaf x -> Interfaces -> Physical Interfaces -> ethX/Y -> right click on it -> Turned off Locator LED
Stay safe
Sergiu
