connectivity problems only with VMs
Hello all,
we have ACI 2 spines & 7 leaves, physical servers, VMWare ESX and few FEXes connected.
• we try to deploy this EPG on a FEX access port, but our VM server1 see many other VMs (from many other EPGs)
we still can access the UI.
The EPG is L2 extended to the legacy network.
we have the connectivity problems only with VMs.
- applied the command:
{"totalCount":"1","imdata":[{"aaaModLR":{"attributes":{"affected":"*/t*/a*_ap/epg-monitor.111_epg/rspathAtt-
[topology/pod-1/paths-1001/extpaths-101/pathep-[eth1/47]]","cause":"transition","changeSet":"encap:vlan-111, instrImedcy:immediate,
mode:untagged, primaryEncap:unknown, tDn:topology\/pod-1\/paths-1001\/extpaths-101\/pathep-[eth1\/47]","childAction":"","clientTag":"",
"code":"E4212023","created":"2020-09-11T11:14:17.841+05:00","descr":"RsPathAtt topology\/pod-1\/paths-1001\/extpaths-101\/pathep-[eth1\/47]
created","dn":"subj-[uni/tn-IT/ap-sys-mgt.it_ap/epg-monitor.941_epg/rspathAtt-[topology/pod-1/paths-1001/extpaths-101/pathep-[eth1/47]]]/mod-4294982841
","id":"4294982841","ind":"creation","modTs":"never","sessionId":"*==","severity":"info","status":"","trig":"config","txId":
"*","user":"remoteuser-deny"}}}]}
and then monitoring showed many VMs down.
we removed the config and was fine again.
scenario:
VMWare server1 monitors VM of EPG associated with a VMM Domain (static port encap) and physical domain.
The EPG is connected to infrastructure using a trunk to Nexus 7K with VLAN’s gateway.
In this EPG are only VM’s in the operationals of ACI (physical machines on legacy network).
any ideas ?
0 Replies 0
