Webcast SD-WAN
150
Highlighted
Delete EPG static binding using xml
Dear all, I am able to do Static EPG binding in PC, VPC, Interface using the below xml file and by POST option in GUI.
How to delete multiple static EPG binding using the xml POST method using GUI
Here is the XML file i got using "save" option in GUI
?xml version="1.0" encoding="UTF-8"?><imdata totalCount="1"><fvAp annotation="" descr="" dn="uni/tn-HOUSTON/ap-APP_PROFILE_PROD" name="APP_PROFILE_PROD" nameAlias="" ownerKey="" ownerTag="" prio="unspecified"><fvAEPg annotation="" descr="" exceptionTag="" floodOnEncap="disabled" fwdCtrl="" isAttrBasedEPg="no" matchT="AtleastOne" name="EPG_VLAN3092_PROD" nameAlias="" pcEnfPref="unenforced" prefGrMemb="exclude" prio="unspecified"><fvRsSecInherited annotation="" tDn="uni/tn-HOUSTON/ap-AP_NONPROD/epg-_TEMPLATE-PROD"/>
<fvRsPathAtt annotation="" descr="" encap="vlan-3092" instrImedcy="immediate" mode="regular" primaryEncap="unknown" tDn="topology/pod-1/protpaths-3471-3481/pathep-[VPC-TO-VMWARE-ESX125]"/>
<fvRsPathAtt annotation="" descr="" encap="vlan-3092" instrImedcy="immediate" mode="regular" primaryEncap="unknown" tDn="topology/pod-1/protpaths-3471-3481/pathep-[VPC-TO-VMWARE-ESX121]"/>
<fvRsPathAtt annotation="" descr="" encap="vlan-3092" instrImedcy="immediate" mode="regular" primaryEncap="unknown" tDn="topology/pod-1/protpaths-3471-3481/pathep-[VPC-TO-VMWARE-ESX119]"/>
Thanks, Kumar
1 ACCEPTED SOLUTION
Re: Delete EPG static binding using xml
Hello Kumar,
You need to add status="deleted"
See an example below.
<fvTenant descr="" dn="uni/tn-PVGAS" name="PVGAS" ownerKey="" ownerTag="">
<fvAp descr="" name="PVGAS" ownerKey="" ownerTag="" prio="unspecified">
<fvAEPg descr="" matchT="AtleastOne" name="AdministratorZone" prio="unspecified">
<fvRsPathAtt descr="" encap="vlan-2" instrImedcy="immediate" mode="regular" tDn="topology/pod-1/paths-104/pathep-[eth1/43]" status="deleted"/>
</fvAEPg>
<fvAEPg descr="" matchT="AtleastOne" name="APP" prio="unspecified">
<fvRsPathAtt descr="" encap="vlan-6" instrImedcy="immediate" mode="native" tDn="topology/pod-1/paths-104/pathep-[eth1/43]" status="deleted"/>
</fvAEPg>
<fvAEPg descr="" matchT="AtleastOne" name="DB" prio="unspecified">
<fvRsPathAtt descr="" encap="vlan-7" instrImedcy="immediate" mode="regular" tDn="topology/pod-1/paths-104/pathep-[eth1/43]" status="deleted"/>
</fvAEPg>
</fvAp>
</fvTenant>
3 REPLIES 3
Hello Kumar,
</fvAEPg>
</fvAEPg>
</fvAEPg>
</fvAp>
</fvTenant>
Spoiler
Hello aleccham It works. I have to accept this is a solution.Thank you.
By the way can you suggest me the xml editor for windows OS. I use notepad++ which is hard to read.
regards,Kumar
Content for Community-Ad
June's Community Spotlight Awards
