831
maxlog
Beginner
EPG label for ExternalEPG release 5
Hi! I can't find menu EPG label for External EPG in ACI 5.1 release. But in previous release it was. Is this feature unsupported now?
1 ACCEPTED SOLUTION
Robert Burns
This is a GUI bug, and is fixed in 5.2.  You can workaround this using the API (as the object model wouldn't have changed) in the affected versions.
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvx59006
Robert
2 REPLIES 2
Robert Burns
Robert
maxlog
Beginner
Robert, thanks a lot for information!
