11-29-2018 09:07 AM - edited 03-01-2019 05:43 AM
I have ACI fabric version 3.2(3n) deployed and have many unused interfaces in the initial deployment. This is dragging the overall Fabric health down. Referred to the following document to suppress fault
How ACI faults are generated and how to selectively prevent faults from being generated
However, there is no option to edit Fault severity assignment policies. Screenshot attached. Is this a bug? Can anyone else see the edit option on this page?
thanks,
11-30-2018 04:36 PM
Are you getting faults? If so, why not just disable (black-list) the interface if you are not using it?
12-03-2018 11:10 AM
Yes, that is an option that is currently used. However, the customer has requested to keep all the ports enabled and the only solution is to set the fault severity, as shown in the document, to be disabled for disconnected access ports. The issue is this setting is not even configurable in the current version. Thus, checking if this is a bug that needs to be registered in version 3.2(3n)
