719
DanLaden
Beginner
Faults persist for decommissioned switches
ACI 4.1(1L)
I have a fabric where I added a spine and leaf for a short time and then decommissioned/removed said switches.
While present, some faults were raised on the switches and did not clear when the switches were removed.  I do not see it listed under registered nodes, nodes pending registration, unreachable nodes, nor decommissioned switches.
How does one clear faults associate with non existant switches?
F1295
minor
Raised
topology/pod-1/node-1002/local/svc-policyelem-id-0/uni/fabric/time-default/issues
Fault delegate: Datetime Policy Configuration for default failed due to : provider-is-not-present-under-default-pol
Config
configuration-failed
configQual:provider-is-not-present-under-default-pol, configSt:failed-to-apply
F1700
minor
Raised
topology/pod-1/node-1002/sys/time
Fault delegate: Ntp configuration on spine SP1001 is Not Synchronized
Operational
protocol-ntp-sync-failed
2 REPLIES 2
Remi Astruc
Beginner
Try to ignore the Fault for one minute.
To do so, right-click the Fault and "Ignore Fault". Then revert the change by finding the created Fault Severity Assignment Policy and deleting it.
Check if Fault is still there.
Remi Astruc
This did not have an impact.  Had the faults suppressed for upwards of 6 minutes.
Thank You,
Dan Laden
