09-22-2020 10:55 PM
Hi folks,
Just want to ask if there's any way to check the SN for the transceivers inserted on the VIC of APIC?
I thought that it would show information on CIMC, but all I could get so far is the PID of the transceiver
Thanks in advance
09-24-2020 06:19 AM - edited 09-24-2020 06:19 AM
I don't believe you can gather SNs from the APIC or IMC directy. You could pull this from the connected switch. If this is a fabric-connected transceiver you can get it from the Leaf (assuming it's connected & discovered).
apic1# fabric 101 show interface eth1/49 trans detail
Node 101 (leaf1)
Ethernet1/49
transceiver is present
type is SFP-H10GB-CU5M
name is CISCO-TYCO
part number is 1-2053783-3
revision is R
serial number is TED1638xxx
nominal bitrate is 10300 MBit/sec
Link length supported for cable assembly is 5 m
cisco id is -- 3
cisco extended id number is 4
DOM is Disabled
DOM info not available
apic1#
Robert
09-24-2020 06:52 AM
Hi @Robert Burns,
It's not that I tried to search for the transceiver plugged into the switches, but rather on the APIC Server's VIC itself. The output of your show int transceiver command display the serial number of the transceiver on the Leaf switch, though.
