IPN devices managing design
Steev112
Dear All,
I am running multipod between two sites using N7K, using two VDCs first for campus and second for IPN, i have configured L3out from BL to campus-VDC my question is if the user want to access the IPN device via SSH,since there is no communication between MPOD-L3out in infra tenant and campus L3out, how can i achieve it?
I have attached example Management option for your reference.
Make Sense ?
BB
9 Replies 9
balaji.bandi
If you made vDC, That means they are 2 Physical Switches, Do you have any physical connectivity between them ?
BB
Hi Bandi,
no there is no connectivity between the two VDCs?
Basic requirement for any device to device reach-ability, you need to have physical connection between the devices, So you need 2 vDC to have connectivity to access and manage them as a management VLAN or Out of Band Management Switch.
BB
I agree with you since this is IPN device is there another option instead of to have links between the VDCs?
another question when i connect the links between the VDC do i need to configure new loopback or managment vlan on IPN-VDC, and configure another ospf process id for management ip address?
Best Practice always connect to out of band management  switch, where Admins can only  able to Manage.
BB
Hi Bandi,
I agree with you but as i know on VDC there is no management interface available, the mgmt interface only on admin vdc. how can achieve it here?
Make Sense ?
BB
Hi Bandi,
Thanks a lot for your assistant.
Glad that it helped you.
please rate the solution.
BB
