10-25-2020 03:52 AM
Hello Team,
I try to discover the fabric and add spines and leaves to it. After that I find out switches status is in inactive and got F3031 fault which indicate Certificate problem. It should be noted that my fabric devices are completely new.
I appreciate it if someone can help me.
Solved! Go to Solution.
10-25-2020 04:00 AM
It could be due to CSCvu62127 bug. If you found F3031 - Fault, you just need contact TAC to install a new certificate containing the matching subject format.
I hope you find it helpful,
Ali
10-25-2020 04:00 AM
Ali
